SHE IS ALIVE!!!!! But.....
Turns out it was the neutral position sensor that was causing the problem why she would not start. THANKS to FFR-ZO6 for sending me the spare!!! The idle was pretty good with only a little surging. THANKS to 'Slowhawk' here for doing the tune. Awesone job and great price.
Now the bad, bad, news...... After about thirty seconds, still no oil pressure. So I shut her down. How long does it take for a new motor to build pressure? I have heard about 15 to 20 seconds. I also have an oil cooler installed, but that should not have too big of an affect should it?
Does anyone have an idea what would cause the no oil pressure? Both oil gallay plugs are installed, the o-ring between the oil pump and pick up tube was checked and rechecked in the install. I pulled the valve covers and there is oil in both heads. More importantly there is oil in driver's side head.
OMG, this has been such a downer finding this. I certainly hope it is something simple.....
Keith
