Oil Life?
Old Nov 21, 2005 | 04:54 PM
Goonie's Avatar
Goonie
Default Oil Life?
I just noticed that my oil life is at 82%
last time i checked (about 2 weeks ago) it was at 47%...
car has never died nor has anything else changed.
what can cause this? I change my oil every 4k and its about half way thus far.
Old Nov 21, 2005 | 05:54 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
What year vette? There are 2 different ways of resetting the OLM
Old Nov 21, 2005 | 06:00 PM
Goonie's Avatar
Goonie
i reset it.... i know how but it changed half way through...
its a y2k coupe...
Old Nov 21, 2005 | 07:23 PM
C5Jim's Avatar
C5Jim
I have a Y2K coupe and if you don't reset the OLM properly it will read 82%. I have no clue why, but it just does.
The answer is to turn the key on - engine off. Go to the oil life % screen, then press and hold the "Reset" button until it goes blank.
It will then read 100%.
There, you're done.
Old Nov 21, 2005 | 08:21 PM
2EZ2BQK's Avatar
2EZ2BQK
From: NorCAL Live your passion--why wait, you ain't getting any younger
I read somewhere that the Oil Life indicator can also be reset by putting the key into the ON position without starting the engine, and mashing the accelerator pedal a couple/three times.
Is someone else has a key, maybe that happened?
To Oil Life?
