ls1 to a ls6 ?
Old Nov 21, 2005 | 10:39 PM
black98c5's Avatar
black98c5
Default ls1 to a ls6 ?
i have a A4 c5 and was wondering how much is it for a ls6 engine?, how much would it be to install the ls6 turn key?, and is it worth it or should i just get a 383?. thanks in advance.
Old Nov 21, 2005 | 10:44 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
If your were going to go stroked do the LS2 402, going with an LS6 is not that much of an upgrade for the bucks spent, unless your engine needs rebuilt. If you do not need a rebuild a heads and cam package would get you more power than the LS6 swap. Just my 2 cents and good luck on what you decide is your upgrade
Old Nov 21, 2005 | 10:45 PM
jlbruggeman's Avatar
jlbruggeman
Putting a supercharger on your LS1 would probably give you the most bang for the buck.
Old Nov 21, 2005 | 11:01 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Yes that is what I did, however I went all out on the forget LS6 and heads so I can crank up the boost. A PS1C would work nicely on a stock motor and will sure put a simle on your face when the boost kicks in
Old Nov 21, 2005 | 11:11 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Have you dyno'd that thing yet???
Old Nov 22, 2005 | 02:50 AM
2MuchRiceMakesMeSick's Avatar
Forget the LS6.
Get forged internals with a 408.
Old Nov 22, 2005 | 12:18 PM
Jstyle's Avatar
Jstyle
Or you can just spray if bang for the buck is all you are out for.
Old Nov 22, 2005 | 01:11 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Jeff,
We dyno my car tonight and was wondering what settings to use for my alky kit.
Steve
To ls1 to a ls6 ?
