Max effort N/A street engine
Old Nov 22, 2005 | 10:21 PM
No Rice's Avatar
No Rice
Default Max effort N/A street engine
Since I have had my fiasco with the clutch, I have decided to just go ahead turn this car into my project car. I was going to sell/trade it in after getting the clutch fixed, but now that I am more involved and will doing the clutch install myself and purchased a lift, I figure this will be a good project car to start with. Was looking at a new C6, but alas it is too small for me. I am 6-4" and about 300lbs and just feel too cramped in it. So now the decision is whether to go N/A or F/I. So what I am looking for is a very rock solid, reliable combination that still has good street manners and pumps out some killer numbers. I don't want to get too exotic with the setup, but enough to blow most cars off the road. I am thinking a sleeved 427 or so abouts. Proven combos preferred. Thanks in advance for the advice.
Old Nov 23, 2005 | 01:25 AM
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
Default http://www.synergymotorsports.net/
Rick is putting together about eight 402-427+ cid LS builds in December alone, almost all with F/I of some sort. He also has a lot of 346-370 motors with F/I being put together this and next month. He personally hand builds each long block and personally tunes each of them.
Freemont, Ca.
510-796-3749
Old Nov 23, 2005 | 09:45 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
If you:
Tell me your budget
Are you doing any work
I can share some info.........
Old Nov 23, 2005 | 01:10 PM
No Rice's Avatar
No Rice
Originally Posted by ALLTHROTTLE&NOBOTTLE
If you:
Tell me your budget
Really no budget, but would like to keep it reasonable. I would think that something between $6-$10k would be good and that should get me a 10sec N/A ride. This is of course just considering the engine and related engine accessories that are needed, i.e injectors, intake, heads, etc. I would probably order a shortblock/longblock from someone and do the r&r myself. I would then have to take it down to L.A to Andys, LAPD, or some other tuner for the tune, since we have no competent people here in Vegas. It would be outright also, no cores involved as I would keep my motor for other projects.
Old Nov 23, 2005 | 02:45 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
402 LS2 motor would be a good move. Killer numbers, cheap price, no sleeves, and you can buy a block right from GM.
Randy
Old Nov 23, 2005 | 05:46 PM
Cruise-In V Veteran
NCM Ambassador
I would say a nice iron block stroker...........400+cid will put out a very reliable streetable drive anywere 500+ at the wheels.........and if you need to spray later you are good to go as well. I am very happy with my 417 stroker. I drive it up to 700 miles one way, flog it on the strip,autocross or roadrace and drive it home.........short block by DRM. Internals for sure....still mostly unknown
Cartek top half.
17-20 mpg on th road, 13 in town and no worse than 9.5mpg while racing.
The 2 tuners you mention should also be able to help with your decision.......Andy sure can help with the cam selection
I believe in the KISS principle........less rotataing stuff is all good for less wear, heat, upkeep and cost. A 150 shot will get you in the 9s if need be
Old Nov 24, 2005 | 12:32 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
We have a wealth of experience in both N/A and F/I motors and can easily supply you with a horsepower solution.
Please give us a call and we can suggest a motor combination based on your objectives.
Thanks,
Charlie
Old Nov 24, 2005 | 02:06 AM
mdhmi's Avatar
mdhmi
Either that or twin turbos. Turbos being my first pick.
Mark
Old Nov 24, 2005 | 10:38 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Believe it!
No Rice, it sounds like you are looking for something bigger than what I'm running, but A&A did right by me with my n/a 402.
Old Nov 24, 2005 | 02:48 PM
#001 2001 Z06
Randy
Exactly, If he wants to do his own install, cheap price, then SDPC
1-800-456-0211
To Max effort N/A street engine
