What torque converter should I use?
Old Nov 23, 2005 | 02:07 PM
EDJ's Avatar
EDJ
Default What torque converter should I use?
I'm going to be swapping out my 2.73 gears with 3.73's. Several people have suggested upgrading out the TC at the same time. My question is what stall speed should I use. I have a 2000 A4 coupe that I use as a daily driver and don't plan on going to the track. Just want more power on acceleration. Any suggestions would be helpful. Thanks.
Old Nov 23, 2005 | 02:11 PM
C5XTASY's Avatar
C5XTASY
Take a look here.
http://www.converter.cc/wizard/wizard2.htm
Then give them a call.
Ed
Old Nov 23, 2005 | 02:28 PM
EDJ's Avatar
EDJ
Thanks, good info on the link.
Old Nov 23, 2005 | 04:43 PM
LeMansBlue04's Avatar
LeMansBlue04
Eric,
Go conservative.
I say this because you indicate you do not want to track the car. That tells me that a great sixty foot time is of no concern to you. It also indicates that you are unlikely to be satisfied with a converter that feels loose on the street.
I have had three so far and I am about to install my fourth. Those of us that drag race, and that means me, like higher stall converters because of the hard hit they apply to the tires and the high torque multiplation they offer off of the line. We are also willing to race with tires that can get a grip when loaded with these high torque levels.
However a guy looking for a purely street converter has a completely different set of requirements. If racing is not in your plans stick with a 2800 stall or a 3200 at the most. Any higher than that and you may find yourself making tradeoffs that simply don't fit your requirements.
Many of the suggestions you will get here may come from racers and their take on things is very different from yours. Be cautious, picking the right converter is almost a black art. If you plan to stay off of the track a converter that feels tight is far better than one that feels too loose IMO.
Old Nov 23, 2005 | 05:40 PM
fsuforever's Avatar
fsuforever
Originally Posted by LeMansBlue04
Eric,
Go conservative.
couldnt have said that better myself ,i just changed my yank 3200 ss & went to the 3600 ss the 3200 is for sale it is a yank btw i have a 00 a4 also with 3.42 gears & alot of other mods
Old Nov 23, 2005 | 05:44 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
I had the Yank SS3200 and for street use it is EXCELLENT. Just swapped in the Yank SS3600 for my drag racing addiction and I love it. Although you can use the bigger converter for your application, my opinion is you will be extremely pleased with the 3200 as it really is a great unit for your intended application.
Old Nov 23, 2005 | 06:46 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Why don't you just change the gears and leave the stock TC in.
Old Nov 23, 2005 | 06:51 PM
Dirty Howie's Avatar
Dirty Howie
I went with the smallest (2400 Vigilante) TC because mine is a daily driver. And I am very happy....I wouldn't want it any looser!!!
DH
Old Nov 24, 2005 | 07:56 AM
BIGMAC's Avatar
BIGMAC
I am very happy with my Pro-Torque 2400/2600. I get great launches at the strip and no looseness on the street.
Old Nov 24, 2005 | 09:33 AM
99 vett babycar's Avatar
99 vett babycar
Eric,
Go conservative.
The thing is , though, that 2 or 3 weeks after you put in my "loose" SS3600 it starts to "feel" just right. Soon you can't remember what the stock TC felt like.
I don't track the car but I do timed road race runs - the only drawback for road racing that I've found with the 3600 is that I have to row my gears a little more to keep the revs up in the turns.
Old Nov 24, 2005 | 07:18 PM
KingTut's Avatar
KingTut
If you want to be able to "spin" the tires from a dead stop easier, then get a TC. I do have the 3.73 gears and I have the Protorque 2400 and it is a nice combination. I did get a used TC at a very nice price and did the install together.
I'm not sure it would have been worth the $700 that a new one would have cost me though.
The gears help at almost all speeds, the TC helps most off the line.
Old Nov 25, 2005 | 08:55 AM
EDJ's Avatar
EDJ
Thanks eveyone for your replys! I believe I will go conserative.
To What torque converter should I use?
