Alternator whistle??
Old Nov 24, 2005 | 08:18 AM
Cig35's Avatar
Cig35
Default Alternator whistle??
Alternator has a slight whistle since I got the car. Not getting worse, but is it normal???. It just annoys me. Cant hear it from inside but can from outside or with the hood up. Bad bearing?
Dan
Old Nov 24, 2005 | 03:00 PM
VMI07's Avatar
VMI07
Are you sure its the alternator.... Belt tensioners are a common source for noise.. What year and how many miles. Over 40k makes this item questionable. Is it different when to air con is on. Separate belt and another tensioner on the air con system
vmi07
Old Nov 24, 2005 | 06:26 PM
Cig35's Avatar
Cig35
Checked all pulleys and belts....did the screwdriver to the ear trick...def coming from the alt. Car has 14k miles
Old Nov 24, 2005 | 07:53 PM
David426's Avatar
David426
Not to compare apples to oranges, but... My 93 eagle talons alternator went bad and I replaced it with a new one that whistles. Could not get an explanation from the dealership, except that it had a 2 year warranty.. No problems so far after 8 months, just makes me wonder..
Old Nov 25, 2005 | 06:30 PM
Cig35's Avatar
Cig35
Anyone else?
Old Nov 25, 2005 | 06:49 PM
EB-Z06's Avatar
EB-Z06
Mine doesn't whistle at all. Most likely will need to be replace. One w/ only 14k shouldn't be bad, but it shouldn't be whistling either.
My tensioner pulley churps just a little every now and then too.
To Alternator whistle??
