Highest Tranny temps on a tock A4 ?
Old Nov 25, 2005 | 11:01 AM
V8_Club's Avatar
V8_Club
Default Highest Tranny temps on a tock A4 ?
What is the max. tranny temp you have seen in your stock A4 ?
Old Nov 25, 2005 | 11:03 AM
idiedtrying's Avatar
idiedtrying
at the track i watched my temp gauge and it went up to around 210, and i was thinking that was too hot
Old Nov 25, 2005 | 11:19 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I watched mine hit 260 then I got a warning message that said "trans temp hot" before I backed down
Old Nov 25, 2005 | 02:52 PM
Johnny_B_Good's Avatar
Johnny_B_Good
St. Jude Donor '05 thru '26
235 degree reading on a 90 plus degree summer day during stop and go New York City traffic. I'm considering having a trans cooler installed bewteen now and next Spring.
Old Nov 25, 2005 | 06:01 PM
davette's Avatar
davette
Since you are located in Dubai, a very HOT location, putting in a tranny cooler is a wise and cheap investment to extend the life of your tranny.
Most coolers will drop your temps 20+ degrees.
If you are seeing tranny temps 220+ with just normal type driving, you need to get a cooler.
Old Nov 26, 2005 | 11:24 AM
99 vett babycar's Avatar
99 vett babycar
I live in South Carolina and have over 400 rwhp on a 45000 mile 99 vert. If my trani temp ever went above 185 at ANY time- summer, winter,road racing, stop and go, whatever- I'd get nervous. Get the best and biggest trani cooler you can find and have it installed -well worth the investment- they don't cost much more than those fancy shift ***** that are so popular on this forum.
Old Nov 26, 2005 | 11:39 AM
David426's Avatar
David426
Mine got up to 250, which was the begining of the end of that transmission. Clutch paks were replace a week later, 2 weeks later I lost 2nd gear completly. Dealer replaced under warranty. Heat is your worst enemy with these transmissions. They will fry quickly. Get an aftermarket trans cooler if you plan on lots of spirited driving, especially in hot climates such a Texas
To Highest Tranny temps on a tock A4 ?
