What controls the Driver Information Center?
Old Nov 25, 2005 | 07:41 PM
SR-71's Avatar
SR-71
Default What controls the Driver Information Center?
maybe I asked the wrong question before......my cruise is skipping numbers on the DIC display and it's pissin me off....
Old Nov 25, 2005 | 07:51 PM
dpd's Avatar
dpd
skipping numbers? explain
Old Nov 25, 2005 | 09:41 PM
vette747's Avatar
vette747
When we hit the switch to increase the speed by small increment, sometimes it add 1 mph, sometimes it skip an mph and increment by 2 mph. This is normal. Is it what you refer to?
Old Nov 25, 2005 | 09:56 PM
SGT. PYLE's Avatar
SGT. PYLE
My Z06 does the same thing. I think it's normal.
Old Nov 25, 2005 | 10:46 PM
SR-71's Avatar
SR-71
thats what it does.......this is normal?...............I don't think mine used to do this....but I guess if it's common I'll overlook it.
Old Nov 25, 2005 | 11:11 PM
ALLEGRO's Avatar
ALLEGRO
on level ground just tap the button to increase or decrease thespeed. If you hold it down long at all it will move more than one mph +/-
Old Nov 26, 2005 | 10:58 AM
SR-71's Avatar
SR-71
Mine does not do that.....I tap the button and it'll either stay at the same # and then I tap it again and it'll skip a number......I don't really think this is normal, but evidently it's common...So I'll just keep on keepin on.....thanks for the responses
Old Nov 26, 2005 | 02:04 PM
R&D's Avatar
R&D
FWIW, the two I've had never did that (1999 & 2002).
Old Nov 26, 2005 | 05:08 PM
ChasNMe's Avatar
ChasNMe
both of mine do it, it just depends on exactly what speed you are when you hit cruise. what i mean is that if you see that you are skipping, you can speed up just a touch on the throttle, turn cruise off and back on, and it go 1 fo 1. it looks to me like a rounding error inside the computer that controls the cruise. i usually F with it til i get it right, but i am ****. another thing you may notice is that the heads up display is 1 mph off from the analog speedo
my $.02
jake
Old Nov 27, 2005 | 12:04 AM
dads01dream's Avatar
dads01dream
Here's another DIC question.... When running without tire sensors, how do you keep the DIC from giving the "check tire pressure" message?
Old Nov 27, 2005 | 08:47 PM
SmashF15C's Avatar
SmashF15C
"what controls the driver information center"
Uh,
The driver?
Sorry, it's been a long family weekend (beer anyone?), wanted someone to laugh with me....
Ready to go back to work,
Smash
Old Nov 28, 2005 | 01:44 AM
jmliles's Avatar
jmliles
Old Nov 28, 2005 | 12:09 PM
fdxpilot's Avatar
fdxpilot
For 01s and later, the Pressure Monitoring System can be turned off using a dealer's Tech 2 Computer. (With the intro of Z06s with no run-flats, the option was added. No such luck for 97-00s) See this link: http://www.stopforce.com/RPO.html
Old Nov 28, 2005 | 05:04 PM
MeekRN's Avatar
MeekRN
it goes by 2 kph not 1mph, so it will skip about every third mph or so
To What controls the Driver Information Center?
