Hoping you could answer a question regarding my recently purchased 01.
I have noticed that the clutch pedal is somewhat squishy, mainly that the first 1/4 to 1/3 of the pedal can be easily depressed, then the remaining pedal travel has some resistance.
Is it common for the pedal to have little to no resistance for the first 1/4 - 1/3 of travel?
I am assuming that I may need to bleed the system (??). Is this complicated?
Also, did the '01 models have the "better" slave cylinder?
