Maganaflow X Pipe Questions.
Old Nov 29, 2005 | 08:10 AM
DADEO1's Avatar
DADEO1
Default Maganaflow X Pipe Questions.
Thinking about putting one on m 99 coupe.
Like the design, cost is about the same as other types.
I have the GHL bullet system and love them.
But do have a little drone at that 1500 RPM area.
My question is to the maganaflow x pipe folks.
How do you like them ?
Any install problems ?
Thanks for your input.
Old Nov 29, 2005 | 02:57 PM
Ron71's Avatar
Ron71
I have the Magnaflow x pipe on mine. No installation problems at all and it helps take away the popping from the exhaust.
Old Nov 29, 2005 | 04:27 PM
Glenn W's Avatar
Glenn W
8th Gear
Default x pipe
Take a look at the Bassani as well. That's the one I have and there is NO popping at all with my Corsa Indy's.
The Bassani, IMHO has one of the better "X" sections that causes scavenging from side to side. Their x is custom made, not just the center section of the two pipes cut off and welded back together. Bassini is high quality stuff too....very well made and fit perfectly when installed.......at least take a look at them.......
Old Nov 29, 2005 | 07:45 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I put on a magna flow x-pipe on my car,wasn't that hard.Made the car a little quieter though.
Old Nov 29, 2005 | 08:26 PM
SnowyATX's Avatar
SnowyATX
Used to have one my car with the GHL's prior to my Kooks install. It definitely helped with the popping but didn't get rid of it...maybe helped by 20% or so. I don't recall what change it made to the sound/tone but it wasn't huge. I bought it to help with the popping.
Old Nov 29, 2005 | 08:35 PM
RdDragn2's Avatar
RdDragn2
Lovin it
Old Nov 29, 2005 | 10:04 PM
Last C5's Avatar
Last C5
Originally Posted by RdDragn2
Lovin it
I run the Magnaflow, but I think the Bassani is very similar.
Installation is a little easier if you cut off the stock pipe with a chain type cutter instead of a sawsall. The cutter leaves a slightly beveled edge on the pipe that aids in the install.
Old Nov 29, 2005 | 10:09 PM
Classical Glass's Avatar
Classical Glass
Default Magnaflow
I have a Magnaflow cat back system on my 02 6sp. Installation was very easy, sounds great with little or no popping out the pipes.
Old Nov 29, 2005 | 10:19 PM
Z28STYLE23's Avatar
Z28STYLE23
Mine works great and love the sound with my stingers. Best part was that it got rid of that darn exhaust jingle. that drove me nuts. Now i have nothin but clean sounding exhaust, install was no prob.
To Maganaflow X Pipe Questions.
