Voltage indication question
Old Nov 30, 2005 | 07:37 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Default Voltage indication question
I've noticed my gauge reads low when I first start up and slowly moves to the correct reading. Is my problem the gauge, battery, or alternator? The battery is a two year old Optima red top. The alternator is original (1998).
The car starts fine even after sitting for a week.
Old Dec 1, 2005 | 04:39 PM
JEEP/C5's Avatar
JEEP/C5
What is your gage reading when your first start it and after it runs. If you start it and run it for 30 min then restart what is it at?
Old Dec 1, 2005 | 08:51 PM
kmthor00's Avatar
kmthor00
My 99' with a new battery will read high 12's or around 12.8 volts while car is off. When cranking it will drop to high 10's or say about 10.75 & then build immediately up to 14.1 - 14.3 hope that helps
Old Dec 2, 2005 | 07:30 PM
Tally Ho's Avatar
Tally Ho
Around 10. It does it every time regardless of how long it has been running. It always works its way back to normal reading within 5-10 seconds of start up.
Old Dec 2, 2005 | 08:09 PM
CSDMagRed01's Avatar
CSDMagRed01
The reading before you start is the battery reading, after start up you are reading the charging voltage from the alternator. The gage does have a lag, but if you shut it off and turn back on to start position so that the gages react but DON'T start the engine, you're reading battery volts only. Make sure most things are off like radio, HVAC fan, etc. Should read 12V. Since there are 6 cells in a 12V battery, if one is dead you get 10V.
To Voltage indication question
