I've searched the forum and haven't found any info on this. I have a 2000 coupe with manual HVAC controls and I would like to switch to the automatic dual zone setup. Has anyone tried to do this or heard of anyone trying to do this? I would appreciate any help pointing me in the right direction.
I don't think it is easy and it is not a good idea. The automatic setup doesn't work all that well - I need to fiddle with it a lot and it is not very reliable. Most people seem to have a problem with dim displays.
I appreciate both of your inputs, but I've got two problems with the current setup.
1) The center console looks exactly like my 98 Olds silhouette and I think it should look better than an 8-year-old minivan
2) My wife's internal thermometer is apparently set about 20 degrees lower than mine. A dual zone set up would save a lot of fighting over the climate controls. Weighing the relative costs of the problems, I'd rather have a dim display and a comfortable wife than no display and constant passenger-side HVAC hijacking.
I assume this will be a pain in the rear, but I really would like to know what specifically is involved before I make the decision. So I guess I'm really asking do you know someone who has tried this before. If not, I'll assume I have to start digging through shop manuals.
Thanks again for the warning, I probably won't go through with this, but working on the car is so much fun.
infact id like to switch back to manual, the automatic controls are time consuming to turn on and adjust, the automatic is cool but not as convienent to operate.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I'm with everyone else. While I haven't had any problems with my electronic climate control (the previous owner did though), it's really not the best setup. I find my Acura's climate control 1000 times more friendly to use.
Don't do it. The auto HVAC is crap. I have a right side actuator that needs replacing at a cost of $188.00 plus 6 hours labor at $86.00 per hour. add in the tax and total it up. I now find out that this has been an ongoing problem for the C5 air conditioning. GM knew of the problem with the actuators (left & right) and are now on their third upgrade since 1997. You would think they would at least make it a little more affordable to repair the problems for their customers when they know it was a parts vender problem. I will get this repaired as soon as I can find a dealer with a Corvette mechanic that knows what He is doing and does not screw everything else up while fixing this problem. The dealer in Daytona had a good mechanic but He is no longer there and I do not think the guy they have now is any good. By the time he repaired a stuck window it cost me $1,386.00 plus another $200.00 to get my CD changer fixed because I think He shorted something out and a lot of my electrical things had to be reset.
If you are determined to make this conversion you will need the complete A/C underdash unit including the vacuum lines and controls. You will also need to replace the under dash wiring harness including the cross brace and the head unit. Make sure the underdash harness is of the same year, transmission and body style (and if equipped with tele wheel) as your car.
Plan to totally disassemble your entire dash. Everything must come out. You will also need to remove the intake manifold and PCV/AIR lines to access A/C, heater lines and bolts behind the engine. I would not do it and I'm a C5 rebuilder.
My wife has the same problem as yours. My solution is to set up the A/C to make her happy and then I close the vents in my direction (and I have dual zone A/C). The comments above about the problematic dual zone are all true. Avoid it and stick with your manual system and trade in the minivan. Short of getting a new wife, It would be easier...
Shirl Dickey
SDRE
That's exactly the kind of information I was looking for. The type of disassembly you described is enough to discourage me from doing this. I was thinking the worst would have to be getting a new wiring harness and maybe a temperature sensor or two.
Thanks everyone else too for giving me the low down on the problems with the dual zone HVAC. They will all come in very useful if I ever decide to sell the car.
You might try your search using something other than the term "HVAC". I always thought that stood for High Voltage Air Conditioning" or "High Volume Air Conditioning"?? . . . Like they use in buildings. I could be wrong??? But you might try using "A/C" or just plain "air conditioning", if you haven't already tried that.
Just my $.02 worth! . . . Okay! . . . Maybe it's only worth $.01!
I have the Auto/Dual Zone AC and have had no problems with it. Although the "dual zone" is kinda of a misnomer in that the passenger can tweak their Air output +/- 5* from what you have... and trust me, that isn't enough to satisfy an easily cilled signficant other or daughter.
