Headlight Adjustment Tool?
Old Dec 2, 2005 | 10:13 AM
NCSU SEE 5's Avatar
NCSU SEE 5
From: Greensboro, NC "REALITY IS MERELY AN ILLUSION, ALBEIT A VERY PERSISTENT ONE"...ALBERT EINSTEIN"
St. Jude Donor '05-'06-'07
Default Headlight Adjustment Tool?
I recently did the Silver Star 9006 - 9005 headlight mod and after I completed the work I noticed the passenger side headlight seems to be just a bit low. I found the adjustment bits, but I can't get them to turn(by hand). Before I go grabbing a set of plyers and mess up, is there some sort of trick or special tool needed to get the adjusters to move?
Thanks in advance for any help! Feel free to PM
Old Dec 2, 2005 | 12:11 PM
SamirD's Avatar
SamirD
I also have to adjust my lights as one of them is too low. According to the service manual, there's nothing special. Just remove the covers, find the two screws, and turn them. How do you like the Silverstars, btw? I was thinking about going with PIAAs.
Old Dec 2, 2005 | 02:10 PM
Roc87's Avatar
Roc87
You can either use a Torx 15, or a 6point socket that fits over the adjustment screw. While adjusting mine with the torx, it stripped the screw, so be careful, they seem like soft metal.
Should put the Silverstar 9005 in the low beam side...1700 lumens compared to 1000 lumens for the 9006 (If I remember right). Just takes a couple minutes work to make them fit. Doesn't blind oncoming drivers because they are still aimed in the low position.
Old Dec 3, 2005 | 05:30 PM
NCSU SEE 5's Avatar
NCSU SEE 5
What he said
Not a bad upgrade if you are changing to Silverstars any way. I am waiting for the price of NotMee's new HID kit to come down a bit and may pull the trigger on that set up
Thanks for the heads up!
Old Dec 3, 2005 | 05:34 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
I installed NotMee's Vette-HID lights last weekend, I adjusted my lights with a 6 point socket, a 12 point would probably work a little better.
Old Dec 3, 2005 | 05:41 PM
rws.1's Avatar
rws.1
Hit the adjusting bolt with some penetrating oil and let it soak for awhile.
they tend to get wet and corroded and then seize up
Old Dec 4, 2005 | 01:49 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Headlamp Opening Door Adjustment
Remove the headlamp opening door. Refer to Headlamp Opening Door Replacement .
For horizontal adjustment:
Loosen the headlamp intermediate bracket to headlamp assembly screws (1).
Adjust the position of the headlamp intermediate bracket (3) as required and retighten the retaining screws (1).
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Tighten
Tighten the headlamp intermediate bracket screws to 2 N·m (18 lb in).
For vertical adjustment: Tighten (to lower) or loosen (to raise) the vertical adjusting screws (2) as needed.
For headlamp opening door stop position adjustment, if necessary: Tighten or loosen the door stop adjustment screw as needed.
Install the headlamp opening door. Refer to Headlamp Opening Door Replacement .
Inspect the fit of the headlamp opening door to the hood, the fender and the front fascia.
If the fit of the headlamp opening door is unsatisfactory, repeat steps 2 through 7.
Old Dec 4, 2005 | 03:33 PM
Ttop34's Avatar
Ttop34
I put the PIAA 9005's in the low beam socket the other day, I've really liked them so far, great improvement over stock. I had Silverstars in my camaro but can't really compare the two like that. I got my PIAA's on Ebay for $41, so not much more than the Silverstars and people claim they are a lot brighter. After cutting off the inside notches, I had to sand down the three outside pieces so they would fit. I fought with it forever only getting in two at a time but after sanding them to fit, got the light snug. Also remember to replace the O-ring with a thicker one so it won't be loose.
Old Dec 5, 2005 | 12:08 AM
SamirD's Avatar
SamirD
Notice
Tighten
Man, my service manual doesn't even have all this! (Well, at least I didn't find it anywhere.)
Old Dec 5, 2005 | 06:27 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
with the Torx driver...it fits right inside the adjustment screw...should be easy to turn
Old Dec 5, 2005 | 07:33 AM
NCSU SEE 5's Avatar
NCSU SEE 5
Thanks!!!!
To Headlight Adjustment Tool?
