Another coolant temp question
Old Dec 2, 2005 | 06:47 PM
Old Rotor Head's Avatar
Old Rotor Head
Default Another coolant temp question
50 degrees outside and I go to 220 at a stop light. Start moving it hits 230 then back down to 190? Am I just getting paranoid in my old age? is this typical?
Owned this baby since new and never noticed this before last week. 80k, I've changed the coolant, blown out the 1/2 acre of dirt in the radiator. Coolant level ok and I still get that smell, could it be a hose collapsing?
Old Dec 2, 2005 | 07:21 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
If it's still stock with the factory programming then thats normal, the first cooling fan is programmed to come on at 225 degrees so watching your coolant go 1 notch above where the fans come on would not worry me but if they were consistently above 240 then I'd start to look for problems.
Old Dec 3, 2005 | 09:06 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
you may have a little air in there
Old Dec 3, 2005 | 09:10 AM
davidfarmer's Avatar
davidfarmer
190 thermostat, 220 fan temp. Perfectly normal.
If there was an air bubble, it would go to 200+ and keep going!
Old Dec 3, 2005 | 09:19 AM
Old Rotor Head
Thanks guy's
Old Dec 3, 2005 | 09:11 PM
phils C5 vette
I thought he was
To Another coolant temp question
