Driving today car started missfiring?
Old Dec 3, 2005 | 03:58 PM
Racie's Avatar
Racie
Default Driving today car started missfiring?
I was driving this morning and my 01 Z06 started missfiring bad. Just out of the blue I had just opened (WOT) it up about 10 min. earlier. I hooked a GM Tech II up to it and ran a diagnostic and it said my #2 and #7 were miss firing? Could it be injectors going out or a vacuum leak. Or maybe coils?
Old Dec 3, 2005 | 04:04 PM
cowpunk's Avatar
cowpunk
Every miss-fire I've ever had on an LS1 has been a plug wire. Remember the basics ( make sure wires are seated correctly). Check your wires, plugs, then coils.
Jay Lee
Old Dec 3, 2005 | 04:50 PM
Racie's Avatar
Racie
Both seem to be snug... I thought it would be strange that 2,7 would go out at the same time (wires or coils...)
Old Dec 3, 2005 | 06:23 PM
69's Avatar
69
Cruise-In VI Veteran
Hello,
Step 1 swap the bad cylider wires to good cylinders to see if the problem follows the wires.
If Not>
Step 2 swap the coils to known good cylinders to see if the problem follows.
If Not>
Step 3 swap spark plugs to known good cylinders to see if the problem follows.
If Not>
Step 4 swap the injectors to known good cylinders to see if the problem follows.
If not>
Step 5 Did you over REV it during a down shift? Mechanical issue (Valves or rings) Perform compression test.
Old Dec 3, 2005 | 08:11 PM
Racie's Avatar
Racie
Default Valve or Springs
Thanks, 69 I'll start going through everything tomorrow. I pray to god it ain't #5 a valve or a spring. I drive it I don't baby it but I don't hit rev limiters or do any ab-normal down shifting.
To Driving today car started missfiring?
