Clicking window ( not rolling down?)
Old Dec 4, 2005 | 02:24 PM
reb854's Avatar
reb854
Default Clicking window ( not rolling down?)
Well with the recent weather change i had the notorious pass side window click on my 00 coupe. After reading many post, i decided it wasnt my motor like i thought because of the code thrown ( b2205) right window downswitch fault. (meaning switch was stuck in down position) I beat on the switch and desided to take a look. So I took the door panel off and determined that u don't have to do that to take the switch out. The switch lifts out from the front and slides out of the panel. Be careful not to damage the door panel ( clips are rough too). So I thought i would have to replace the 179. 00 switch but i tried unpluggging it and operating it with the drivers switch and it worked. when I plugged the pass switch up it has worked fine ever since. Please try this before givin high dollars for switches. P.S. some sell on e-bay for around 10 bucks.
Old Dec 4, 2005 | 04:05 PM
SR-71's Avatar
SR-71
Sweet, those are the best kind of problems. The one's that are fixed for free
Old Dec 4, 2005 | 05:05 PM
Phidelt076's Avatar
Phidelt076
Good job. My passenger window has been out for the past few weeks. Tried the slam the door with holding down the power window button and no dice. I checked my DIC and it shows no codes. I will be taking her apart in the next few weeks to see if I can figure something out. Inspecting the regulator, motor, etc.
To Clicking window ( not rolling down?)
