Another dreaded code question...
Old Dec 4, 2005 | 11:40 PM
99vert's Avatar
99vert
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Another dreaded code question...
My check engine light came in. I was able to pull 2-codes:
A6-scm B2605 H C: I found this was the front vertical seat sensor.
10-PCM p0161 H C: This one said it was a Heated Oxygen Sensor-heater circuit bank2-sensor2.
My question is what would cause the p0161 code to appear? Will it be okay to drive a ways with this code?
Rich
Old Dec 5, 2005 | 02:49 AM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
It will be fine to drive with that code. It saying the 02 sensor on the passenger side behind the cat is not reading. No big deal, if you need a replacement let me know, i have one laying around you are welcome to. The only o2 to worry about are the ones before the cats (sensor 1) as those control your a/f ratios.
Old Dec 5, 2005 | 03:19 AM
cheemsaf's Avatar
cheemsaf
Also, try resetting the code and see if it pops back up again. If it doesn't show up, your O2 sensor may be okay, if it does come back (most likely it will) then you know for sure it just didn't get a bad reading from it & it's bad.
Old Dec 5, 2005 | 12:25 PM
99vert's Avatar
99vert
Thanks guys.
Mr Big-I will let you know about sensor. How hard is to install myself? I don't get under her to often.
Old Dec 6, 2005 | 12:53 PM
Mr. Big's Avatar
Mr. Big
All you need it a 7/8 wrench, takes about 15 min from start to finish. Pm me if you need one
To Another dreaded code question...
