It could be the switch under the brake pedal thats out of adjustment . Drive down the freeway and take your left foot and pry out your brake pedal and then set your cruize control and if it set that means your switch needs to be adjusted. Mine stop working and that what was wrong with mine.
you are the man!!!! Thanks alot you have saved my right foot from alot of work. I guess when I was doing the nitrous install on the car I hit the piece and knocked it lose they had 2 pieces I snapped them both back in. the cruize works great and it seems like when I hit the break the car kinda goes into neutral when i let off it kicks back in. I guess this is normal haha but cruise works!
