Racetronix pump question
Old Dec 6, 2005 | 01:36 AM
JetVette01's Avatar
JetVette01
Default Racetronix pump question
Ever since i installed my racetronix pump with hotwire kit it seems to act funny. When I get somewhat low on gas, my car begins to stutter and hesitate. I would be able to run it way past this level before the pump swap. Is it just cuz this ones pumps so much more that it might be sucking in some air or something? I also notice that after I fill up, it only shows about 3/4 tank. After driving on the freeway I can almost WATCH the gauge go down. Continues to go down. When I shut the car off and then restart it later on it goes back to a higher level. Any help would be greatly appreciated.
Old Dec 6, 2005 | 08:37 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
sock filter and the fuel level float could be interfering with each other for the gauge problem. The loss of pressure issue might bea loose clamp on the pump outlet hose.
Old Dec 6, 2005 | 09:06 AM
IM QUIKR's Avatar
IM QUIKR
It sounds like you'll need to pull it out and reposition it. Something is hanging up in the tank.
To Racetronix pump question
