On the C5 (1999) there is a page button on the left side of the drivers steering wheel. You can display on the HUD: oil pressure, temp gauge, and fuel level.
When the ignition is on, the HUD defaults to fuel level. For some reason, it sometimes defaults to oil pressure level (the oil can symbol displays). Now this doesn't happen everytime and I always reset to fuel level...but it started happening a few weeks ago.
I just got an oil change and the shop didn't fix it though I mentioned it. I assume its some glitch in the computer system.
I mean the memory button on the door that saves seat position, hvac setting, steering wheel position, radio stations, etc., for two different drivers......I don't know if this was an option so you may or may not have it.
Yes seat, steer wheel and mirrors and it may save the HUD page you select, i.e., fuel gage, when you reset your memory. I'm not completely sure but I no longer have this issue. Then again I did replace my battery a few months ago, so..........
