1 Door doesnt power lock 1 doesnt unlock
Old Dec 7, 2005 | 02:33 PM
stope's Avatar
stope
Default 1 Door doesnt power lock 1 doesnt unlock
Like title says, my passengery won't power lock (regardless if i use the inside lock or my remote lock), and my driver door won't power unlock (regardless if i use inside lock or remote lock). It didn't used to be like this, and its kind of a pain. Can anyone help?
Old Dec 7, 2005 | 02:47 PM
EHS's Avatar
EHS
codes please.
Old Dec 7, 2005 | 03:38 PM
stope's Avatar
stope
which codes? It's a 98 coupe 6 spd f45/climate control.
Old Dec 7, 2005 | 07:28 PM
EHS's Avatar
EHS
https://www.corvetteforum.com/techti...D=26&TopicID=1
The complete list is at the bottom of that link, as a separate link.
Old Dec 7, 2005 | 07:32 PM
stope's Avatar
stope
no codes are tripped, everyone has an H.
Old Dec 7, 2005 | 08:19 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
LDCM(left door control module), most likely one of the relays is worn out
this is a badazz thread that should help you, bump it up if it does
http://forums.corvetteforum.com/show...327&forum_id=1
Old Dec 7, 2005 | 10:23 PM
stope's Avatar
stope
thanks a lot man! I tried searching for it but came up w/ nothing. I"ll check it out this winter break, and bump the fix forum if that was the problem - which it seams to be.
Old Dec 7, 2005 | 10:35 PM
EHS's Avatar
EHS
connecticut gives good info.
To 1 Door doesnt power lock 1 doesnt unlock
