Ti Exhaust
Old Dec 9, 2005 | 06:00 PM
Blue260's Avatar
Blue260
Default Ti Exhaust
Are there any clearance problems putting Z06 Ti exhaust on an Auto.
thanks, chris
Old Dec 9, 2005 | 06:03 PM
see5's Avatar
see5
No, none
Old Dec 9, 2005 | 06:38 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Fits just like the stock set up
Old Dec 9, 2005 | 07:05 PM
jrose7004's Avatar
jrose7004
It fits just like it was made for it!
Old Dec 9, 2005 | 08:03 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Old Dec 9, 2005 | 08:48 PM
Dark-Knight's Avatar
Dark-Knight
NOpe, as a matter of fact, it's a good thing.
Old Dec 9, 2005 | 08:53 PM
MTurnbo's Avatar
MTurnbo
Just finished doinf it. No problem.
Old Dec 21, 2005 | 08:05 PM
JasonS's Avatar
JasonS
Hi guys,
Just a quick question - I understand you need to jack the rear end up > 30" to get the exhaust removed ....this will sound like a very dumb question, but how do you support the front of the car while you do this when using a floor jack (other than using a garage hoist).? (i.e .that the car doesn't roll forward and off the jack). Even with some wooden blocks, they're nowhere heavy enough to prevent the beast from rolling around. Any advice would be really appreciated.
Cheers
Jason
Old Dec 22, 2005 | 08:19 AM
dunbindun(tov)'s Avatar
dunbindun(tov)
If you are not really setup for this i.e. do not have a lift, I would just find a competent dealer/muffler shop to do the job. I had mine done at a dealer for $85. You can probably get it done for $75-100 without eating the exhaust due to a shaky lift. Will also need new gaskets.
DBD
Old Dec 22, 2005 | 09:25 AM
Mr. Jones's Avatar
Mr. Jones
this is a easy swap, a shop could do it in 30-60min.
if you do it yourself, start by lifting the front about a foot and put it on stands. now lift the rear 30" plus. if you don't lift the front you will have the nose crushed on the floor.
Old Dec 22, 2005 | 07:38 PM
JasonS's Avatar
JasonS
Thanks for the feedback gents ...based on the cost, I think it will be safer to just have it done at the shop.
Thanks!
Jason
To Ti Exhaust
