What is the widest wheel and tire can you fit once you mini tub? What are the performance results with mini tubbing? I know Vipers hook well with 18x12's and BFG's, but will a C5 have the same response if it rolls on the same type of wheel and tire?
Depends, how much HP do you have. Wider tires do not hook much better, more for looks. Just get a sticky tire the widest you can fit on your current rims.
I'm right at 500hp(flywheel) and when i added the 19x12 rims all i got was about 20% more traction.....so the cost/performance ratio obviously sucks. This mod is mostly just for looks.
But to anwser your original question, 12" wide rims are pretty much the norm on a tubbed C5, however there have been a few that went to a 13" wide rim and added wider rear fenders to cover them.
