How Do You Check For Codes?......
Old Dec 11, 2005 | 04:18 PM
bcseitz's Avatar
bcseitz
Default How Do You Check For Codes?......
Guys, I know this a dumb question but I just got my first "Check Engine Light" this afternoon, :***** : How do you get to the codes on the DIC?
Thanks in advance!
Old Dec 11, 2005 | 04:44 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
Turn the ignition on without starting the car
Hold down the OPTIONS button while pressing the FUEL button 4 times within 5 seconds.
The car will cycle through all the modules and their codes automatically
Once its gone through the codes, you can cycle through them manually using the top four buttons
I believe the top two cycle between the Contol Modules and the next two ("3" and "4") cycle between the codes for that module
You can clear codes by holding the RESET button while looking at the codes for a module (This will clear all codes for the module at one time)
H at the end of the code means it happened prior to the last time the car was successfully started. C means it happened the last time the vehicle started.
If you don't find any "C"s, I would clear them all and then wait for the next fault to set. There can be a lot of old H codes in memory and it can make it hard to figure out which one set the code and triggered the Check Engine Light.
p.s. Clearing the codes will typically reset the Check Engine Light
Good Luck
Old Dec 11, 2005 | 06:58 PM
bcseitz's Avatar
bcseitz
Good Luck
Glenn, Thanks for taking the time!
I'll check it out in the next day or two.
Bob
Old Dec 12, 2005 | 12:36 PM
FASTFORM's Avatar
FASTFORM
Glenn,
I wanted to thank you also. I am a new Vette owner and am getting acquainted with all the technology of the C5.
Old Dec 12, 2005 | 07:34 PM
Lovin It!!! - C5
You guys are more than welcome. I've gotten a lot of help from the folks on this Forum and am only happy to help others when I can. Take it easy and enjoy your ride
I'll be cruisin' in mine tomorrow
To How Do You Check For Codes?......
