Oil Pressure Gauge
Dec 12, 2005 | 03:13 PM
Oil Pressure Gauge
The oil pressure gauge on my 98 vette when started goes all the way to 80 the max and stays there and when killed goes back to 0 what could this be? Just the sensor or is the gauge bad? What do you recommend?
Dec 12, 2005 | 03:15 PM
IMHO buy the sensor first it is only like $33.00.
Dec 12, 2005 | 03:18 PM
Quote:
Is it easy to replace? where would it be located?
This is the bad sensor symptom. Intake needs to be pulled forward 6 inches to access the sensor. Not a difficult job.
Edit: I found the DIY.
Oil Sensor DIY
Dec 12, 2005 | 03:26 PM
Oil Sensor DIY
So is screwed in the back of the block? I have to unbolt the intake to get to it?
Dec 12, 2005 | 03:34 PM
Yup! Standing strait up behind the intake on the block on the drivers side.
Dec 12, 2005 | 03:43 PM
Here is a picture.
[IMG]
[/IMG]
Dec 12, 2005 | 03:56 PM
the C5 is know for them to go bad from time to time..sorry..its not hard to change..
Dec 12, 2005 | 04:55 PM
Here is a picture.
[IMG]
[/IMG]
WHy the hell do they make these things such a pain in the *** to get to?? So there's no other way to get to it without pulling the intake?
Dec 13, 2005 | 02:48 AM
Thats the only way. It should not take that long. 2 hours at most. Just make sure you have the torque specs and sequence for the intake installation. The intake has a rubber gasket so you wont have to replace any gaskets. Good luck. As soon as mine arrives I have to do the same thing.
Dec 13, 2005 | 02:56 AM
Quote:
No -- there's been a rash of these things lately.
Dec 13, 2005 | 04:09 AM
This just happened to me as well
Dec 13, 2005 | 04:22 AM
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Quote:
well you can fix that when you fix the clutch and install the headers
mine is staying broke for now...
oh..BTW slow down
Dec 13, 2005 | 11:37 AM
Thanks guys for all your help!
Dec 13, 2005 | 08:04 PM
Bad Sensor
Hi, mine went bad about a month ago (99 vert), had it replaced for $270. Cost might have been a little pricey but I was just to lazy to tackle the job.
