I am going to buy a set of 4-tip Borla Stingers for a 2000 Corvette and take them to a shop to get them installed. Around how much does it usually cost to install a setup like this? Just dont want to get screwed, because I am rather new at this. Thanks
Also, the cheapest price I have seen on the net is around $760 shipped, anyone know where to get them cheaper?
Install could run antwhere from $60 to $125. Depends on your area, an exhaust shop, dealer, mechanic, etc. Don't pay over $125 unless you absolutley can not work a ratchet.
Don' try to remove your old exhaust unless you have a lift. Because its REALLY hard to get the vette 30" off the ground.
I kept my old exhaust just in case when or if I resell the vette. If its to the dealer the old exhaust goes back on (sell the Stingers on ebay), if to an enthusiast the exhaust stays, my choice.
I've done 2 or 3 exhausts on c5s without using a lift...I cut my old muffler off, others we saved without cutting. I'd say if you have a low profile jack, some jack stands, can turn a bolt and have a few hours free on a Saturday afternoon, you can install an exhaust. It truely is one of the easiest mods to do. Good luck!
I paid 100 for a cat back install. I think 760 is a pretty descent deal shipped. Not sure you will find a better deal, unless of course you decide to go with the magnaflow magnapack instead.
I found a used 4-tip stinger here on the forums for $500 in pristine shape. Seller was local and met me half way. Can't ask for better people then vette owners. Shop near me charges either 1 hour or 2. Cant remember. But I think 2 hours labor is a little steep seeing as how it seriously only takes 15 minutes once the car was on the lift. It must be one of the easiest things ive ever seen.
When I installed my Indys, I raised my rear as high as I could. Supported with jack stands and then cut the stock junk off with a sawz-all. The install was easy. I prefer to do it my self to assure that it's performed correctly and I don't have to go back for any adjustments.
If you are mechanically inclined you should have no problems. Be sure to think safety first. Jack stands and safety glasses, etc...
