Spark Plug Gap?
except I run anti sieze on plugs.
I always go with the regular NGK copper plugs. I'd much rather go with a fresh set of those every 6 months instead of doing platinums or iridiums for longer intervals. It's kind of ironic, since I'm the guy who likes to go 8k or longer on my oil change intervals with synthetic oil.
I changed the plugs once on my aunt's '98 vert and it was a bear for the #7 plug and I was so afraid of cross threading one.
Any tips? I'm getting my Z06 dyno-tuned in January and I want a fresh set of plugs in. I run HPDE's in the car and it runa a hair rich at WOT.
I assure you I've had more plugs in and and out than you can count.Jr.
Dad had a gas station for years for christ sakes.
and my first post is absultely correct. When we had the old points,gaps were say 28-32,Because there was not enough voltage to dependly light a larger gap.Electronic ignition replaced the points gaps widened. Wider is better, Wider gap needs more voltage Want learn something
call Jacob's and talk to there tech's take your issue's up with them.
Don't care what you think you know. They have 8 coils on a LS-1, one on a
prevoius v-8 Why! hotter spark.LESS Fouling,
My 4 cly pick up has 8 plugsWhy more flame kernal, Factory found more power, better combustion.
Your dad owned a gas station, so that makes you a high-performance ignition expert.
But my dad's a minister, so I have divine insight!
A larger plug gap is NOT analogous to two plugs per cylinder.
I've spent considerable time on the phone with Jacobs and read their literature. I just haven't ever seen any racers that run their ignition. Nor have I ever seen anyone with an exceptionally fast car that had their ignition. Not to say that there isn't someone, somewhere. Also not saying it's bad stuff. Just that considering the huge benefits that Jacobs claims, it seems to be, uhmm, "under-recognized" by the hard-core performance community.
Multiple coils have been in common use for at least 25 years on motorcycles, and (coincidentally?) that's where I've had my worst misfire problems. Aftermarket hotter ignition was no help. Solved with a narrow gap, no reduction in ETs.
I've never said that a wider gap doesn't require more voltage. Only that lack of voltage isn't an issue for most of us, and more voltage isn't the cure for most misfires and plug fouling. A large gap is much better for firing lean mixtures, with the tradeoff that it is more misfire prone at high cylinder pressures, regardless of the voltage. I'll gladly sacrifice idle quality to be sure that it's hitting on all 8 at full throttle.
At this point I'll defer to MadBill
As far as tips go, the plugs are pretty easy to do on these cars, just be sure to have a few different extensions in your socket set as some plugs work easier with longer extensions while some work better with a real short one. It helps to completely remove the plug wire from the coil too. None of the plugs are obstructed too much, so even if you take your time you can still get it done in well under an hour (as long as none of them are stuck in there that is)
Why don't you contact the people that make the plug that you finally choose and ask them
The longer you are going to leave the plugs in, the more important it is too.
RonJ ...
