Need advice fast, which x-pipe is better
Old Dec 14, 2005 | 12:19 AM
big gil's Avatar
big gil
Default Need advice fast, which x-pipe is better
corsa x-pipe or bassani x-pipe, want to purchase tomorrow. will go on corsa pace car system on 02 vert.
Old Dec 14, 2005 | 12:36 AM
mdhmi's Avatar
mdhmi
Very little difference from one x pipe to another from what I've seen. X pipes are good for reducing the popping noise on deceleration, but, that's about it.
Mark
Old Dec 14, 2005 | 05:01 AM
rwj383's Avatar
rwj383
LGM 3" Pro Race X-pipe. While you're ordering that, might as well get the rest of the LGM C5 Race LT header kit!! Very bad *** results.
Old Dec 14, 2005 | 05:14 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
all the same ..pipes are pipes. hehe
Old Dec 14, 2005 | 06:08 AM
Dark-Knight's Avatar
Dark-Knight
If you're talking about replacing the entire center section of your system check out Random-tech, it's a true x with intergrated hi-flow cats.
Old Dec 14, 2005 | 06:35 AM
Shane_S's Avatar
Shane_S
I say get the LG Pro Long tubes and X-pipe. You'll be glad you did.
Shane
Old Dec 14, 2005 | 09:05 AM
Gordy M's Avatar
Gordy M
Several OEM's have evualated H-pipes and horspower. They found that the closer the H-pipe to the cats the more HP they made. Max gain on an 02 Z06 was 4 rwhp. I would assume the same is true with the x-pipe.
Old Dec 14, 2005 | 09:06 AM
jrose7004's Avatar
jrose7004
Since you have a Corsa system I'd get the Corsa X-Pipe because it was designed for your system!
Old Dec 14, 2005 | 10:47 PM
EHS's Avatar
EHS
All the same. Buy by price.
Old Dec 15, 2005 | 07:08 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Most will say the one they have is the best, but, as pointed out in the above thread(s) a pipe is a pipe, is a pipe. Good luck w/ your selection.
Old Dec 15, 2005 | 05:42 PM
99 vett babycar's Avatar
99 vett babycar
which one can you buy cheaper ?? That's the one.
To Need advice fast, which x-pipe is better
