HID conversion from Blinglights.?
Old Dec 19, 2005 | 12:52 AM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
Originally Posted by c5mtl
i also listened to the guys that said dont bother with hid's in stock lens....the cause glare.....so i went the way of ecodes!!!what a big mistake..spent money on e codes and has not happy..yes i had a sharper beam but no real extra light output....then i went ahead and bought some 6000k hids for the ecodes.....WOW thats what i was looking for....never been flashed.....if i was to do it again i would have bought 4300k hids for the stock housing for $300 ...trust me ...u want light buy....cant go wrong for the money
Thank you!!! Soo many people don't understand that stock halogens can only put out soo much lighting! the E-codes only use halogens in the "upgraded" lense. not much of a upgrade if u ask me!!! U need HIDs to put out more light! the difference in output is mind boggling!
Aj
Old Dec 19, 2005 | 12:59 AM
edensknight's Avatar
edensknight
Originally Posted by Shane_S
Yah Turns out his kits are $1150.00. Looks great but thats way too rich for my blood. C6 rims will definately be the next thing at anywhere near that price level.
Shane
Old Dec 19, 2005 | 11:38 AM
JTS97Z28's Avatar
JTS97Z28
Aj
Well thats not always true. Infact I just upgraded the lighting in my Jeep Cherokee and I stayed with halogen because I didnt want to spend much money like I did on my vette HID setup. I ended up going with the e-code IPF H4 housing with higher wattage IPF 80/110 watt bulb and obviously made my own harness to support the higher wattage bulbs. The output is unbelievable!! my halogens actually over power HID projector equipped cars that are driving next to me at night. I love them!
Old Dec 19, 2005 | 11:45 AM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
seriously? what yr Jeep? if its the newer style, perhaps u may be able to, but the older Jeeps don't have anything. i have one of them too and want to upgrade the lighting.
But heres the thing, how much did u spend on upgrading the e-code housing, wiring, bulbs, misc cost, and your time...add all that up, is it cheaper then $300??? if not, wouldn't the HIDs be a better setup. If you look at the output rating of halogen vs HID, they put out ~1800 lumens vs 3200 lumen (6000K kit), respectively. the numbers alone tell you HIDs are better. what the e-code lenses do it aim the light a lot better right? upgrade your wiring to use high wattage bulbs helps to...
but ur right..there are other ways to do it. personally i feel HIDs are the best way to go. I have been changing bulbs for god knows how long, silverstars, piaas,etc, none of those compare to my HID setups. and i get a ton of compliements, yet no flashings on the road...
to each their own people...
Aj
Old Dec 19, 2005 | 05:09 PM
EVILNESS's Avatar
EVILNESS
Aj
Ive messed around with all kinds of bulbs from the 30 dollar Nokyas to the 89 dollar raybrigs and nothing compares with HIDs. I also went thru at least 3 new sets of wiring harness since the higher output halogen bulbs were frying my harnesses. I will never do that again there a reason why most new vehicles and i believe some day all vehicles will have HIDs. Cause they are better.
R.
