Shock Replacement, When ??
Old Dec 15, 2005 | 12:05 PM
Steveo1c5's Avatar
Steveo1c5
Default Shock Replacement, When ??
Is there anyway of knowing or telling when the stock shocks need to be replaced? My 01 has 40,000 miles on it, and lowered on stock bolts about 1/2+, it seems my front air dam is hitting the ground easer under certain circumstances then it use to. Thanks for any input.
Steve
Ok for those recommending the Bilstein shocks, which ones would be good for a stock replacement, heavy duty, or Z51 sport setting, also I read on Ecklers site that they will add a 1/2 " of height and trigger a warning light. I don't want to add any height, is this typical with any shock I install.
Old Dec 15, 2005 | 03:11 PM
Dirty Howie's Avatar
Dirty Howie
My opinion for what its worth.....I think the cars settle mostly from the springs over time.
I had new Z06 springs and shocks put in when it was lowered about 20K ago. The front has settled an additional 1/4 inch...now at 25 7/8 inches.
I have also seen OLDER vettes without lowering that look LOW.
DH
Old Dec 15, 2005 | 03:25 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
40,000 they are junk get some Bilsteins
Old Dec 15, 2005 | 04:01 PM
PrimeC5's Avatar
PrimeC5
I was noticing the same thing about my car scraping but I have F45 so I'm not sure where to get replacement shocks or what to do to fix the problem
any ideas?????
Old Dec 15, 2005 | 04:07 PM
99 vett babycar's Avatar
99 vett babycar
shocks do not hold your car up.
Old Dec 15, 2005 | 04:11 PM
PrimeC5's Avatar
PrimeC5
so it's more likely the springs worn out?
Old Dec 15, 2005 | 05:27 PM
99 vett babycar
shocks DAMPEN the vibration of your springs - they take the rebound out of the spring's oscillations. The springs are the main "supporter" of the car.
The best thing to do ( my $0.02) is get the suspension inspected my a quality shop that does suspension work.
But, yes,if I had to guess based on the limited information you give, I would think a new set of springs ( C5 or Z06) would do wonders for your car AND if the shocks are found to be leaking then have them changed out at the same time. If it turns out that you're going to be replaceing F45 shocks BRING ALOT OF MONEY.
Old Dec 15, 2005 | 05:45 PM
JoshVette's Avatar
JoshVette
Good thread.
Old Dec 15, 2005 | 05:46 PM
alanh's Avatar
alanh
If you think it's starting to scrape too much, adjust the bolts to raise it up a little bit.
Old Dec 15, 2005 | 07:28 PM
WKMCD's Avatar
WKMCD
Old Dec 15, 2005 | 11:13 PM
John Shiels
put them on a shock dyno or at least pull them and inspect them. They are junk like all OEM shock you will be glad when you get some Bilstiens. I did my Dodge dually and it never ran so good in it's life at 50,000. They felt so good I did my Excursion at 9,000 miles and don't regret that either. Stockers are made to get you off the lot.
Old Dec 16, 2005 | 08:19 AM
Joe's Eray's Avatar
Joe's Eray
Old Dec 17, 2005 | 09:29 PM
Steveo1c5's Avatar
Steveo1c5
Old Dec 18, 2005 | 11:53 AM
Old Rotor Head's Avatar
Old Rotor Head
I replaced my stock Z51 shocks at 45k with Bilstein Sports and saw nothing that Ecklers states? Oh, and I'm lowered on stk bolts.
Old Dec 18, 2005 | 08:25 PM
thug29's Avatar
thug29
Got the info for the shocks, so how about a recommondation for the springs....brand/style etc.?
Why would you choose the C5 style over the Z06 ? Or would you buy an after market brand instead of GM ?
Thanks.
Old Dec 21, 2005 | 08:43 PM
psycho-mullet's Avatar
psycho-mullet
Regarding spring choices we've got a thread going on in the Autocrossing & Roadracing forum that might be helpful:
http://forums.corvetteforum.com/show...post1553237834
To Shock Replacement, When ??
