selective ride control- removal
Old Dec 17, 2005 | 05:45 PM
caster's Avatar
caster
Default selective ride control- removal
I purchased some Bilsteins and need to know how to remove the SRC shocks and install the new ones without thowing a code into the DIC. Any links out there for this process??
I'd like to sell the used shocks, any ideas as to the value of these things??
Old Dec 17, 2005 | 06:48 PM
Oldvetter's Avatar
Oldvetter
You need to install resistors to prevent codes, not sure on value. You could measure resistance of shocks to determine.
Old Dec 17, 2005 | 06:59 PM
BanditDude's Avatar
BanditDude
You can also have it removed from your computer completely. Check out this link. It goes into all of your options.
http://forums.corvetteforum.com/show...9&forum_id=103
Old Dec 17, 2005 | 07:01 PM
sting072's Avatar
sting072
6th Gear
You can disable the selective ride control feature with a Tech 2. There is no need to buy resistors or simulators. There have read postings in the past with a link that contained instructions on how to do it.
Old Dec 18, 2005 | 07:46 AM
C5COM67's Avatar
C5COM67
Tech 2 would be the best, but a 15 ohm resistor in each plug will do the trick
To selective ride control- removal
