alignment
Old Dec 21, 2005 | 06:18 PM
scott forbs's Avatar
scott forbs
Default alignment
I lowered my C5 on stock bolts and need to get an alignment. Do I need the back wheels aligned? Also will I aspect to have any issues with it getting aligned properly (ex.needing to drilling extra holes to align)?
Thank you,
Scott
Old Dec 21, 2005 | 07:12 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Eh, it is pretty much a crapshoot. I don't think an alignment is completely necessary as most will say here, but to be on the safe side it is a good idea to do it.
When my vette was lowered on stock bolts I had it aligned. It was off 1/4 inch on either side. It was subsequently lowered again when my bushings were cut and I have not had it aligned. As far as I can tell there is no uneven tire wear, but the car does feel a little unstable over 125mph. I don't know for sure if this is due to the alignment being off.
Old Dec 21, 2005 | 08:05 PM
yellow01's Avatar
yellow01
Get it aligned, no extra holes or mods will be needed. While you may get away without doing so, why? It WILL be off from ideal, and why not have performance vehicle up to spec?
The isntability that icemanskis is experiencing may be due to aerodynamic effects. The C5 was designed to have some rake (lower front than rear) to assist in downforce and prevent pressure buildup under the car. many many pictures I see of lowered vehicles here lower the rear ALOT. If the rake is lost, this is exaclty what you will feel - higher speed instabilty or 'float'.
HTH.
Old Dec 21, 2005 | 10:03 PM
C5COM67's Avatar
C5COM67
Just do it and get it checked. I did, it wasn't too bad, but you want the best setup and conditions for your car. Also make sure it is level left /right after you do it. Check after a couple of days and some miles on it.
Old Dec 21, 2005 | 10:22 PM
Gordy M's Avatar
Gordy M
If you lower on stock bolts, set the rake and then corner weigh the car, you will be amazed at how much out of alignment you can be.
Old Dec 21, 2005 | 10:28 PM
Dark-Knight's Avatar
Dark-Knight
Tires for these cars are expensive, don't take a chance get the car aligned.
Old Dec 22, 2005 | 05:28 PM
scott forbs
Thanks for everyones input. I lowered my C5 as low as it could go on stock bolts and the rear ended up being lower than the front. Should I raise the rear up a little to make the rear ride higher than the front?
Scott
Old Dec 22, 2005 | 05:44 PM
nuke61's Avatar
nuke61
You want ~1/2" of rake. I recently had my car aligned and FYI, it was $160 for a LIFETIME (as long as *I* own the car) alignment at my local Goodyear Tire store. Hunter laser alignment, before and after specs. Very nice, and I plan to have it checked/aligned every year.
Old Dec 23, 2005 | 03:35 PM
scott forbs
Question, what does corner weigh mean?
Old Dec 23, 2005 | 05:27 PM
edensknight's Avatar
edensknight
HTH.
Old Dec 23, 2005 | 07:29 PM
DngrZne's Avatar
DngrZne
They put a scale under each tire, and by comparing the weight at the different corners they use the ride height to adjust the weight balance of the car to get it to where it should be.
Old Dec 24, 2005 | 12:05 PM
scott forbs
As far as the 1/2" of rake. Is that measured from the top of the tires to the wheel well or from the ground to the wheel well?
Old Dec 24, 2005 | 01:12 PM
yellow01's Avatar
yellow01
Measure from the ground to the frame rail underneath the car near the tow hook holds.
If you look up under behind the front wheels and in front of the rear, you will see cutouts in the rocker panel where there are holes for the shipping hooks. Near these holes there is a bit of frame exposed. Measure there to the ground.
don't trust body panels. They can be off more than you'd believe.
Old Dec 24, 2005 | 04:17 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Best place to measure is the ground to the side frame rail (the actual rail not the fiberglass) right behind the front wheels, and right in front of the rear wheels. Try to get the rear 1/4" - 1/2" higher than the front to prevent air from getting under the car and causing high speed lift.
When you lower your car, the camber will go more negative and the front toe will go in, rear toe will go out. It is a good idea to get it aligned after lowering.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To alignment
