burning smell please help
Old Dec 21, 2005 | 08:59 PM
elev84u's Avatar
elev84u
Cruising
Default burning smell please help
i have a 2002 corvette coup ..manual... i have noticed for about a month when i drive it once i stop i smell a burning smell.. i have noticed no driving problems everything seams to work fine...the car has 14/000 miles on it and it has been babied...any info would be appreciated the warranty runs out at the end of this year... thanks in advance
Old Dec 21, 2005 | 09:33 PM
turboc5's Avatar
turboc5
Did you run over a plastic bag? It may be melted to your exhaust. Take it to the dealer. It wouldent hurt. Just have them look it over anyway since your warranty is going to be up soon. It might just need to be driven more , JK mine gets 20k mi a year
Old Dec 21, 2005 | 09:55 PM
nightmel's Avatar
nightmel
Under warranty get it in to be looked at. Burning smell could be oil coming from Oil sending unit rolling down the back of your motor down your bell housing onto your Catalytic Converters. But if its under warranty don't wait get it in now! Good Luck.
Old Dec 21, 2005 | 09:57 PM
EHS's Avatar
EHS
Could it be clutch or brake related?
Old Dec 21, 2005 | 10:26 PM
Shane_S's Avatar
Shane_S
It could be a bunch of stuff. Without smelling it for myself I wouldnt even try to guess. Take it in and have it looked at.
Shane
Old Dec 21, 2005 | 10:36 PM
EHS's Avatar
EHS
Shane
My apologies. I was just trying to be helpful.
Didn't mean to offend you with silly guesses.
Old Dec 21, 2005 | 10:55 PM
TEXHAWK0's Avatar
TEXHAWK0
Could be your wife fuming because she does not get to drive it!
Old Dec 21, 2005 | 11:11 PM
Mehfoud's Avatar
Mehfoud
Post a pic of the smell
I am guessing it is the clutch.
Old Dec 22, 2005 | 03:01 AM
Cscokd's Avatar
Cscokd
Oh my....can you give us any better clues? Any unusual noises? fluid leaks under your car? functions that do not work anymore? any error codes, messages or warning lamps? Does it smell inside the cabin, engine bay or generally everywhere? Are you driving any particular way when it happens? Here's a few ideas to think about:
1. Does it smell like burning oil? Check for oil leaks in and around your headers.
2. Does it smell like hot electrical smell? Could be serious. Inspect for anything that has stopped working, blown fuses, etc.
3. Does it smell like melted plastic? Check wiring harnesses near your headers. Spark plug wires, O2 sensors, etc. Check your mufflers and pipe tips near your rear facia. Check for plastic bags melted onto your pipes.
3. Does it smell like burning brakes? Check your brakes. Check your eBrake.
4. Does it smell like burning rubber? Check your serpentine belt. Stop burning tires at the stop lights.
5. Does it smell like hot exhaust fumes? Check for exhaust leaks. Sometimes cats going bad will smell also.
6. Does it smell worse than hot brakes? Check your clutch. Check your clutch master cylinder for leaks and low fluid.
7. Does it smell worse than anything you ever smelled before? Check your pants!
Old Dec 22, 2005 | 06:35 AM
Shane_S's Avatar
Shane_S
ROFL I wasnt offended.
Didnt think that my post had a curt or emotionally distrought tone to it. Guess i need to use more emoticons.
Shane
Old Dec 22, 2005 | 12:08 PM
99 vett babycar's Avatar
99 vett babycar
get the car up in the air at the dealers and LOOK while smelling.
Old Dec 23, 2005 | 02:29 PM
DSimonini's Avatar
DSimonini
Had the same problem. Checked the usual suspects, never found it and it stopped. It didn't seem related to any particular driving habit, like braking, acceleration (clutch&trans), or tires. Still a mystery. Good luck. I'd be interested if you come up with something.
Old Dec 23, 2005 | 02:54 PM
edensknight's Avatar
edensknight
Shane
Old Dec 25, 2005 | 01:12 AM
brandon1566's Avatar
brandon1566
I had the plastic bag issue a few times the first time I didnt know what it was. after the 2nd time I knew right away. seems like plastic bags and corvettes are best friends.
To burning smell please help
