Throttle body removal
Old Dec 22, 2005 | 07:52 AM
bowtiebubba's Avatar
bowtiebubba
Default Throttle body removal
Anyone have any how tos on removing the throttle body? Never done this before. Thanks Guys
Old Dec 22, 2005 | 08:44 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
remove the air bridge and coupler. Remove the two coolant lines on the throttle body (front lower section, belowthrottle body opening). Disconnect the electrical connectors (one on each side) Then remove the three 10mm hex head bolts holding the the throttle body to the inake manifold and catch with your free left hand
Old Dec 22, 2005 | 11:14 AM
AnteVenom's Avatar
AnteVenom
Daytona Jam 1 Veteran
I would add that you will want to place a clean towel/rag over the opening as soon as possible after removal to prevent anything from getting/blowing into the intake opening! Might save you trouble down the road.
Old Dec 22, 2005 | 08:57 PM
bowtiebubba
Thanks guys for the help.Took it off tonite. The 2 coolant lines at the bottom of the throttle body was a bear to get off.
Old Dec 22, 2005 | 09:12 PM
vetteamerica's Avatar
vetteamerica
Dont put them back on just connect them together, will make it that much easier next time and prevents hot antifreeze from running through your TB
Old Dec 22, 2005 | 09:33 PM
502ci's Avatar
502ci
Just connect the two lines with a metal tube and a worm clamp on each end. Driven my car for years in cold and warm weather and never noticed anything different with this mod, "bad that is". Cooler air is better air.
Old Dec 23, 2005 | 06:38 AM
bowtiebubba
Sounds like a good idea,that will definetly be done when i put it back together.Do i need to do anything with the 2 openings for the coolant on the throttle body?
Old Dec 23, 2005 | 08:28 AM
JoeyG's Avatar
JoeyG
you can cap them off if you's like. Otherwise just forget about them
Old Dec 23, 2005 | 05:35 PM
edensknight's Avatar
edensknight
Don't you just love the support that can be found in this forum. You guys are awesome!
Old Dec 23, 2005 | 07:13 PM
Hoosier44's Avatar
Hoosier44
you can also go to corvette garage.com and buy the tube with coupler in a kit.Seems like it was less than 50 bucks.
scott
To Throttle body removal
