cam size
Old Dec 27, 2005 | 11:15 AM
burnin red's Avatar
burnin red
Default cam size
I do not know alot about cam size, would this be considered a big cam, or one that would lope alot, be easy to drive, any ifo would be nice just wanting some info, The cam is a 228/228 .588/.588 112
thanks
Old Dec 27, 2005 | 11:32 AM
byte_me's Avatar
byte_me
thanks
you should list what you want to put it in to help...if its an auto or manual...Z06 or regular C5 etc...
For instance...a 112 LSA on an auto may make it tough to tune for idle...and an auto can require a higher stall converter to achived the RPM power band a cam would operate in..
Old Dec 27, 2005 | 01:38 PM
burnin red's Avatar
burnin red
it is an 2002 z06 sorry
Old Dec 27, 2005 | 09:54 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
I have that cam with a 113lsa in my Z. With the kooks, no cats, and stingers, it sounds great. Nice lope, and the car sits there and shakes like a muscle car. Along with ported and polished heads, I am putting down 448 rwhp and 410 rwtq, and top end that seems endless!!!!
Old Dec 27, 2005 | 10:15 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
thanks
Baby cam. Go with a LG G5X-3 on a 112LSA if you want lope and power
See sig...
Old Dec 27, 2005 | 10:55 PM
NXTFAZE's Avatar
NXTFAZE
My advice is to go bigger
Old Dec 28, 2005 | 12:20 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I just recently installed a F14 cam which specs out at 232 I 234 E with about .600 lift of each side. It lopes the worst when you cold start the car, but a good tune helps me drive the car daily. Not to mention I made 423 rwhp with the cam and bolt ons.
Old Dec 28, 2005 | 02:57 AM
black98c5's Avatar
black98c5
I plan on going with the F13 cam on a 114 lsa with the idle set low so it can really lope nice
Old Dec 28, 2005 | 05:25 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
I have that cam in my '02z and it is awesome. It has a pretty dood lope to it (because of the 112lsa). The lower the lsa the choppier the idle. I also put on a set of G.M. Performance cnc heads, LG L/T's cold air kit and 3" duals with SVO 30# injectors. The car made 450 RWHP and most people can't believe that kind of sound comes from a new vette. It does not stop pulling until the 7,000 rev limiter.
Old Dec 28, 2005 | 05:33 PM
burnin red's Avatar
burnin red
sweet, thanks
Old Dec 28, 2005 | 05:41 PM
Rhode Warrior's Avatar
Rhode Warrior
Is that ported & polished stock heads?
Old Dec 28, 2005 | 08:12 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
Yes, stock ported and polished heads.
That is two cars now putting down 450rwhp with this "baby" cam!!
Old Dec 28, 2005 | 08:15 PM
Rhode Warrior
Nice numbers, I have a Futral F11 228/230 on a 112 LSA with ported and polished stock heads, ported TB, long tubes, etc. Have not had it dynoed yet. Hope to have similar numbers.
Old Dec 28, 2005 | 08:28 PM
wps5's Avatar
wps5
any suggestions on a cam that will not create that "muscle car" effect? Looking for something that is you cant really tell until you need it
Old Dec 28, 2005 | 09:50 PM
roushraven's Avatar
roushraven
Coolest Guy Evar!
Make that three, I have that cam in my H/C Z too.
-RR
To cam size
