I looked and found a couple of threads re: instaling the PIAA Fog Lights but has any one connected to the stock harness the girl at PIAA said I should be able to but dosent know anything about Corvettes???
I got a set for Xmas and ordered the stock switch. I'm curious about this also.
My vette has been in the shop for about 2 weeks for a goodies install & one of the problems was that the stock fog lamps would not fit...long story short, I have PIAA 1100's on my car, but will not see it until Thurs or Friday...I'll ask the Xtreme guys about this when I go pick it up on Thurs or Friday & get back to you on this.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
You can connect the On/Off switch to the stock foglight switch - but all the rest of the wiring you must use the PIAA wiring (needs a relay and heavier gauge wire)
