I have a set of Maya wheels on my 01 ZO6. 20" & 19" I am looking to purchase a C6 and can't get a definite answer to see if they will fit. Does anyone know for sure? Thanks.
Everything that I've heard is that the bolt patterns will match, but the offsets are way different. The C5 wheels will stick out of the fender on a C6.
The fronts will probably be ok.
The difference in offsets between stock Z06 rears and C6 is 21mm - that's a healthy 3/4 inch further outboard. Look at the C6 and see if this is acceptable to you. If your current rears have more than 58mm offset, the difference will be less.
