Rough Idle
Old Dec 28, 2005 | 02:53 PM
indy300's Avatar
indy300
Default Rough Idle
My 2001 idles fairly rough (at about 700 rpm) and the car shimmies. When I bring the rpm's up just a little it is very smooth. I replaced the spark plugs and wires a few months ago and it helped a tiny bit. Any ideas? Thanks in advance.
Mike
Old Dec 28, 2005 | 02:56 PM
99Red&White's Avatar
99Red&White
Mike
You could try a Fuel Injector Service, or better yet, run a can of CLEENS through your engine and clean it out. Another name for CLEENS is seafoam. Just go to your chev dealer and ask for 2 bottles of CLEENS. Read the directions. Have someone maintain Idle while you pour it into your intake. (There are several area's you can do this). Let the car sit for awhile then start it back up. It will run rough for a minute or two, but stand back and watch all the white smoke pouring from your exhaust. This is all the carbon build and crap being blown out!
Jason
Old Dec 28, 2005 | 03:29 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Use an inductive pick up light (timing light) to check the coils... we have learned over time the coils can be marginal (not hitting all the time) and yet not throw a problem code in the computer. SO when you hookup the inductive unit, what you are looking for is a steady strobe on each coil. IF one hits with an irregular beat... you have found a bad coil.
VR
Old Dec 28, 2005 | 04:29 PM
RedC5's Avatar
RedC5
My '98 has done this since I drove it home new from the dealer....with the exhaust sound....I like it a little shakin'. Some passengers have also said they like it....
Old Dec 28, 2005 | 07:42 PM
RonJ's Avatar
RonJ
VR
Now, there's a good idea!!! Sure beats checking coils with an ohmmeter, and an ohmmeter doesn't always show intermittents!!
RonJ ... TY ...
Old Dec 28, 2005 | 07:48 PM
kendo347's Avatar
kendo347
I had a rough idle when cold of my fbody. I replaced the o2 sensors and that cured my problem.
Old Dec 28, 2005 | 09:18 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Mine shakes at idle some, but I have a fidanza aluminum flywheel with less weight to dampen the motor. I'd try the basic tune up stuff.
1. Clean MAF wires with alcohol (something that evaporates)
2. Check/swap spart plugs.
3. Check wires with OHM meter to make sure all are good. I believe factory spec says under 700 is good.
4. Do what vetrdstr says and check the coil packs to see if they're working right.
If you putz in your car try to sea foam setup to break up any carbon deposits.
Old Jan 2, 2006 | 01:24 PM
mrtoner's Avatar
mrtoner
I had put a pick up light on mine a few months ago, and saw irregular flashes on several coils - I thought my light was bad. Now I will look closer....might be why my O2 sensors are black and sooty...
Old Jan 2, 2006 | 02:07 PM
vetterdstr's Avatar
vetterdstr
let us know how it works out for you!!
VR
Old Jan 2, 2006 | 04:32 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Mine has always had a slight shake. When I questioned it a few months ago with the rest of the forum, it was the consensus that some shake is normal.
Old Jan 2, 2006 | 06:20 PM
Jake T's Avatar
Jake T
Old Feb 4, 2006 | 09:41 PM
LotusFan's Avatar
LotusFan
Has anybody looked into an engine grounding kit to smooth the rough idle?
I have one on the Nissan 350z I bought for my wife and it idles and revs MUCH smoother than other 350z's we tried.
I did a search here on "grounding kit" and got zero results. The Z forums are crawling with talk on this. It's very popular with that crowd.
It's supposed to somehow make the signals the ECU reads much cleaner, thus the better decisions by said ECU.
Claims made by grounding kit makers:
- increased throttle response
- a cleaner spark
- a cleaner ECU signal
- an improved idle
Can any of you senior guys comment on this idea?
thanks,
Rich
Old Feb 5, 2006 | 09:51 AM
vette98c5's Avatar
vette98c5
Do a compression check if your car is a mn6,and you missed a shift you may have bent a valve. That is exactly how it acts have seen it many times
Old Feb 5, 2006 | 10:25 AM
jers98vet's Avatar
jers98vet
Mike
Clean your MAF. It's probably dirty. Especially if you are running an oil empregnated filter such as a K & N. Oil can cet on the element and cause a rough idle but will run fine at higher rpms.
To Rough Idle
