Need help..stripped a bolt
Old Dec 29, 2005 | 11:00 AM
GMvert's Avatar
GMvert
Default Need help..stripped a bolt
Stripped a bolt on the muffler hanger, what are my options? I have no idea how to get to the bolts that seem to be in the frame.
Old Dec 29, 2005 | 11:22 AM
gdphillipsvette's Avatar
gdphillipsvette
Are these the two bolts that hang from inside the frame to support the muffler? I "lost" one for about 30 mins while I was installing my GHL system. I "found" it using a magnet. The only was to get access into the frame to change out a stripped bolt is to remove the rear fascia. Good luck to you!
Old Dec 29, 2005 | 11:29 AM
EHS's Avatar
EHS
Can you cut the hanger?
Old Dec 29, 2005 | 12:44 PM
out2run's Avatar
out2run
Are the mufflers still bolted up with the nots on the bad threads?
Old Dec 29, 2005 | 03:36 PM
GMvert's Avatar
GMvert
I think I may solved the problem. I just bought a #10 tap/dye and will attempt to re-thread the sucker.
gdphillipsvette-we should get a poll going on the longest time to search and rescue that pair of muffler hanger bolts hanging down with in the rear frame....1.5 hrs for me last night I about went nuckingfuts!
Old Dec 30, 2005 | 08:45 AM
out2run's Avatar
out2run
Congratulation, you are lucky to spent that little time fishing!
Hope you put a flat clip on the bolts to grip that u-bolt (and keep it from getting pushed back into the bumper).
Old Dec 30, 2005 | 11:18 AM
gdphillipsvette
GM vert - consider that it was a "personaility test" - you passed!
Old Dec 30, 2005 | 01:18 PM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
Not familiar with the part you are working on but if it has a #10 tapped hole now can't you drill and tap it for a 1/4-20. Chuck
To Need help..stripped a bolt
