Shock change labor hours WTF????
Old Dec 29, 2005 | 02:57 PM
Jstyle's Avatar
Jstyle
Default Shock change labor hours WTF????
I was going to change them myself but I just am so damn busy lately. I was gonna drop it by the local stealership but they wanted 350 in labor to change the shocks. How many labor hours is it on a 00 with base suspension?
Old Dec 29, 2005 | 04:21 PM
COLORADO FRC's Avatar
COLORADO FRC
I seriously doubt $350 worth! I normally pay my mechanic about $80 an hour, can't believe over 4 hours for shocks. Should be a 2 hour project at most???
Call Midas or someone like that and see what they say!
Old Dec 29, 2005 | 04:27 PM
GUSTO14's Avatar
GUSTO14
I just did mine last weekend and 4 hours might be a safer number. In any case I'm betting the labor rate in the Springfield (Va) area is close to $90 an hour or more, so it's probably pretty accurate for a dealer.
Having said all of that, there are plenty of write-up's on it and for $350, I'd sure try to make time to do it.
Good luck... GUSTO
Old Dec 29, 2005 | 06:48 PM
vette dan's Avatar
vette dan
Vette Dan
Just had my new Bilsteins installed and it was $100 for install. At $25 a wheel I wouldn't do it.
Good Luck.
Old Dec 29, 2005 | 07:07 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Remember.. The "Stealership" doesnt set the hours. GM does..
4 hours labor is about right. Considering you need to lift the car, remove the wheels, remove the shocks, install the new shocks, road test the car, etc etc..
You could probably do it in less time though if you do it yourself..
Jeff
Old Dec 29, 2005 | 07:10 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
this WILL take 4 hours if you don't zip tie or wire the shocks compressed before installing, don't worry about using a small wrench to hold the front shaft through the wheel well, just move the w/washer and coolant tanks out of the way and hit them with air from the top, if you were closer i'd offer to help
Old Dec 29, 2005 | 07:16 PM
mike348's Avatar
mike348
With a lift and right tools 4 hours sounds lazy.
Old Dec 29, 2005 | 09:21 PM
GUSTO14's Avatar
GUSTO14
Sorry... I'm just slow.... even with a lift and all the right tools...
GUSTO
Old Dec 30, 2005 | 01:37 PM
2000BSME's Avatar
2000BSME
who the **** has a lift laying around? Not a very common "appliance" found in the corvette owners garage.
Old Dec 30, 2005 | 01:47 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
Actually ALOT of corvette owners have lifts in their garage. If you go into the F/I, Tech, or Performance forums I bet 2-3 out of 5 owners have a lift.
Old Dec 30, 2005 | 01:55 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
4 hours is a lot of time to change the shocks with a lift. I don't remember the exact time it took us to change the shocks on my car last time, but I am sure it was under 2.0 hours.
Old Dec 30, 2005 | 02:13 PM
chriswtx's Avatar
chriswtx
2 hours for a pro mechanic if he takes his time...
Old Dec 30, 2005 | 02:19 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
and if he goes out for lunch. I can do a brake job in my driveway in 1 hour. New pads and rotors. I don't expect them to do it but 4 hr's in BS
Old Dec 30, 2005 | 04:47 PM
2000BSME's Avatar
2000BSME
I am fully aware of the fact that a few people have lifts in there garage. Some guy asking how long a shock job on his vette would take is probably not one of them. I think it's prolly safe to say less than 1 in 50 vette owners have lifts in their garage, especially not this guy. That's all I was trying to say.
Old Dec 30, 2005 | 05:21 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
If the mechanic tried to replace all 4 shocks in 2 hours, I wouldnt let him work on my car. Cause he's not paying attention, he's just slapping the parts on and tightning the bolts. I guarantee he's not taking the time to torque and check his work..
Old Dec 30, 2005 | 05:48 PM
chriswtx's Avatar
chriswtx
2 hours would be slow for me at work with a lift and all the tools to do the job and that includes checking everything with a torque wrench.. Just because your a fast mechanic doesn't mean your not doing it right.. Just means you know what your doing and have done it before. Saves alot of time not having to think about what your doing, just jump in and do it and do it right...
Old Dec 30, 2005 | 06:15 PM
LS9's Avatar
LS9
With air tools and 2 floorjacks , I did all four in 45 minutes.
To Shock change labor hours WTF????
Old Dec 30, 2005 | 07:04 PM
88sk's Avatar
88sk
damn I got the std. now upgraded 2k susp. ,I also just ordered a lift,if you were closer Id do it for $50,its an easy job w/out a lift
Old Dec 30, 2005 | 08:25 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
I agree at most 2 hours. Took me about 1hr a piece never doing them before.
Do the fronts one night then do the rear another night. Do pay stealership prices.
Old Dec 30, 2005 | 10:31 PM
LS9's Avatar
LS9
for $350 you could buy a compressor and tools too.
