So....I got this
Dec 31, 2005 | 03:40 PM
So....I got this
floor jack from Sam's last year for my Harley.
I want to paint my rotors this winter, and I did jack up the side of the vette to see if it would work. It did and mostly lifted the rear, but kinda the front oo... It kinda has a flat part that touches the car near the jack point... The weight limit is 1,000.. Am I crazy to use this for a couple of hours while I paint away?? Would you..or should I get a board to put a hockey puck on or do it like this???
Dec 31, 2005 | 06:39 PM
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I think you should be ok....I mean the whole car only weighs like 3200 pounds.....never hurts to put some jack stands under there though just in case
Dec 31, 2005 | 07:16 PM
Safety first NEVER NEVER NEVER work on a car that is only on a jack. ALWAYS put jack stands!!!!!!!!!!!!!
Happy New
Year
Jan 1, 2006 | 08:31 AM
Hmmmm...
OK..
Ya think I'm stressing the frame by not picking it up right on the puck spot?
Jan 1, 2006 | 12:17 PM
Quote:
Originally Posted by Groucho
OK..
NO YOUR STRETCHING YOUR LUCK WORKING W/O JACKSTANDS!
Jan 1, 2006 | 12:29 PM
St. Jude Donor '11-'25
Use Good Jack Stands
I had a 1967 GTO fall off cheap jackstands in 1974. The wheels were off because I was getting the drums cut.
The problem was that I was laying under the right side of the car trying to get the pass exh manifold off to replace the heat riser.
I was told that it looked like the scene from the Wizard of Oz (when the house landed on my ex-wife, I mean the wicked witch).
I was very lucky, the only injury was a (still) split fingernail (from the exhaust pipe/finger/oil pan sandwich).
Please practice car jacking (that doesn't sound right).
I now have a Mohawk lift, and good quaility jackstands.
I was very lucky, not everyone is.
Bob K.
Jan 1, 2006 | 12:51 PM
This is what happens when things go wrong, bad jack, bad jacking position. I heard a creaking and rolled out of the way just in time. $700 and 2 weeks later, car was repaired. I can think of a couple of things:
Safety First
Anything worth doing is worth doing right
It costs less to do it right
Scared straight!
Jan 1, 2006 | 04:24 PM
Quote:
Happy New
Year
Jan 1, 2006 | 04:44 PM
Quote:
Safety first do not become a statistic
Jan 1, 2006 | 05:12 PM
St. Jude Donor '05
I am guilty, I did it!
Jan 1, 2006 | 05:20 PM
Thanks...
I'll probly put a couple of wood blocks to use a jack stands..Now..where did I put those blocks??
