Lower temp thermostat - bad idea?
Old Jan 1, 2006 | 08:49 PM
coast7's Avatar
coast7
Default Lower temp thermostat - bad idea?
Looking to start some discussion on this issue. The conventional wisdom here seems to be that installing a lower temp (160 degree) thermostat and programming the fans to turn on at a lower temp will reduce the operating temp of the LS1 engine and improve performance.
In the January '06 issue of Corvette Magazine, the Tech Nerd on page 36 says this is NOT a good thing to do. For those not subscribing, the Tech Nerd says the GM engineers (Evil Twin comment!) designed the engine to operate at the temps delivered by the stock thermostat and fan settings and reducing engine temps will not improve performance, but may hinder it.
Old Jan 1, 2006 | 08:54 PM
Alex D's Avatar
Alex D
I agree !! I had low temp thermostats in my LT4 and LT1 Vettes, but would not put one in my C5.
I don't think they are any good for the LS1 or give additional power. My car's coolant consistently runs at 194 to 199 degrees, even in the summer in 90F weather with the air on and my oil temp is always 200 to 219 F ... all perfectly healthy.
Oil MUST reach 219F (100C) ever so often to fully burn off all condensates that contaminate it.
Old Jan 1, 2006 | 09:17 PM
Jim Taylor's Avatar
Jim Taylor
I did the lower thermostat/fan settings soon after I got my car back in 2000. Driving around here in DFW weather (hot summers, mild winters), they do nothing for my operating temp. The cooling system can only do so much, and the car runs as hot as if I'd left it stock.
Old Jan 1, 2006 | 11:10 PM
BAD_TCR's Avatar
BAD_TCR
Some one must have did you wrong then cause I run a 160 T-stat all year long in the DFW area and the temp drop compared to stock is signifant and noticable. Normal car moving temp now is around 180-186. Traffic/stopped is around 200-205. Definte change from stock!
I also monitor my oil temps as after all it is that oil/engine temp that really matters....and I have no problem reaching 219F in my driving with a 160 stat, even while the coolant stays at a lower temp, but I do drive 30 minutes as a DD with a lot of lights in the city.
So, yes theoritically, your lower stat will reduce temps as the engine works creating more dense air, which will equal more power. Is it a lot? No, not really, but a tuner is going to recommend it. Do you benefit any other way? Only, in your mind, because yes these engines were designed to run hot, but it always got me so worried and nervous to see my temps climb. Now with the 160, I never worry about the temps and the engine still reaches high enough temp to do its job with contaminates. Do what you want to do, take into consideration the climate you live in, driving habits, etc...whether you are getting it tuned and want to do any other mods, etc...
Old Jan 1, 2006 | 11:14 PM
EHS's Avatar
EHS
Originally Posted by BAD_TCR
...So, yes theoritically, your lower stat will reduce temps as the engine works creating more dense air, which will equal more power. Is it a lot? No, not really,... Do you benefit any other way? Only, in your mind, because yes these engines were designed to run hot,...
There's the answer.
Old Jan 2, 2006 | 12:47 AM
502ci's Avatar
502ci
Try running your car at the dragstrip with the stock thermostat then run it with a 160 degree thermostat and lower fan settings. Your times will be all over the place (stock) and much more consistant (with the 160). Not to metion .10 quicker which eqauls 10-15 h.p. I`ve put a 160 in all of my performance cars over the years and swear by it, and I have heard every opposing view.
Old Jan 2, 2006 | 06:28 AM
EHS's Avatar
EHS
I like to drive my car more than a 1/4 mile at a time. Especially when I'm trying to get somewhere.
Old Jan 2, 2006 | 06:37 AM
Warp Factor's Avatar
Warp Factor
The biggest benefit is probably with forced induction, where lower temps make the engine less likely to detonate.
Might also allow more timing (and power) normally aspirated with a retune.
Old Jan 2, 2006 | 07:39 AM
MeekRN's Avatar
MeekRN
Default its not a benefit
if your driving in a race, you can dump dry ice on the intake manifold which will lower temps and give more power, if your trying to out think GM, its a lost cause. the LS1 is designed to run 4000rpm for 4000 hours straight, and it does it without failure, infact some airplanes are adapting the LS1 to planes (which will include A/C). the typical aircraft engine which produces 350 hpr costs about 50K. 7000 for the LS1. to have said $50K engine rebuilt cost more than a new LS1...
Old Jan 2, 2006 | 07:42 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Old Jan 2, 2006 | 08:33 AM
502ci's Avatar
502ci
I am saying there is a proven benefit, most people running an LS1 at the track use a 160 for a reason. Now put the race track aside, I have taken my vette on 1,000+ mile trips since 1997 and have had the thermostat on since 98 and never had a problem in cold or hot climates."Trying to out think GM?" What do you think the aftermarket does. Or should I say they make parts to go faster, because GM is great don`t get me wrong but there building cars for the general public. The next comment will be "why didn`t GM put in on at the factory then?"
Old Jan 2, 2006 | 08:42 AM
EHS's Avatar
EHS
Why didn`t GM put it on at the factory then?
xjcharity's Avatar
xjcharity
St. Jude Donor '21
I've had a 180 degree in mine for years, no problem. The car runs cooler because the fans are programmed to come on sooner.
Old Jan 2, 2006 | 09:04 AM
Warp Factor
Probably fuel economy and emissions.
Old Jan 2, 2006 | 09:08 AM
502ci's Avatar
502ci
Exactly!!!
Old Jan 2, 2006 | 09:10 AM
byte_me's Avatar
byte_me
to all who say it's supposed to run HOT for increased power...
it is set to run hot for EMISSIONS ONLY! PERIOD.
decreasing your cars temps make things last longer- I run a 160* stat and have the fans set to run lower as well...the car runs MUCH better at lower then 235* I stay at 185* to 190*. Try sitting in rush hour traffic @ 235 + and see if your ********* don't start to shrivel up...that is WAY too hot for an all aluminum engine to be running in my opinion...I have never had an issue running a 160* in my 97...I also noticed that the tranny temps also decreased as a result of this change...
Do it, and drive it like you stole it!
Old Jan 2, 2006 | 09:21 AM
502ci's Avatar
502ci
MeekRN I just red your signature "the worst mod on a corvette is better than the best mod on any other car!! Learn it live it.
To Lower temp thermostat - bad idea?
Old Jan 2, 2006 | 10:07 AM
EHS's Avatar
EHS
Well, here's another thread on the same question:
It includes comments like these:
Originally Posted by jimman
This is total BS you need to learn about thermal conductivity with AL and combustion efficiency. This is no longer the 50's with cast iron engines. Check all the dyno graphs that have been posted recently all are better with the hotter temps. I just finished 50 pulls and the best are 200 plus.
I just remembered I hold a patent on Thermal Dynamics.
and
Originally Posted by Michrider
There are numerous engineering requirements that go into thermostat selection, not just one of needing to light off the cats soon.
Yes a cooler t-stat may net quicker times. If your building a race car, that's a good choice. Owning a street car that should last 100K and beyond, I'd lean toward OEM selection.
Even if we just went down the road of cats not lighting off soon. Any detrimental effects? What if those cats go bad and mr dealer scans the data and finds out the silly thing is never reaching proper operating temp. Mr customer gets a huge bill.
Why do nascar teams heat their oil to nearly 300 degrees? Hot oil, cool intake charge = faster lap. Instead of cooling the entire engine down with the wrong thermostat, they heat that motor and oil up and direct cool air to the intake.
The cooler engine isn't really what's making more power. It's tricking the FI system to richen up the fuel. Same car probably has also opened up the intake and exhaust and is now running lean on the factory tune - the perfect recipe for detonation. Cool the engine down to trick the computer for a richer mixture and vwalla more power because your out of the detonation and closer to an ideal AF ratio.
I think a better approach is tuning to match any mods that have gotten the engine into the detonation problem.
Ever see all the problems a lot of imports are having with oil sludging. Most of it is due to small engines that hardly generate any heat, can't burn off the condensates. So we have here a V-8 that generates nice heat, never any sludging problems, is knocking 30 - 40 degrees off it's operating temp the right thing to do. Most powertrain engineers would say maybe for a race car, but your street car came from the factory with the right thermostat.
and
NASCAR runs their coolant in the 220 to 230 degree range. 358 cu in 800hp and run 9500-rpm's all afternoon. Cool air not cool engine especially with aluminum, thermal conductivity is so high with al vs. iron it's tough enough to keep the head temp where it should be. Long term reliability is in question not only with not burning off contaminates but short trips where engine doesn't reach temp causes shut down in a rich condition and you get cylinder wash down. This then let's you start on a dry cylinder next time out. Long trips no problem but a few thousand cold starts and you will wind up like I did with my 85 and 88 with scored cylinder walls at 70Kmiles sucking 1 quart to 500 miles. Before you all go nuts and start throwing tuner names around you might want to talk to one of the good ones like I’ve done and you will find out that the low temp therm is ok if your going to drive 1400 ft and wait in line an hour to do it.
and
Originally Posted by WHINER
changing the t-stat is a band-aid.
there are radiators that WILL fit.
you'll make more powerand have longer engine life at 190-195 degrees than at 160.
EVEN if you have a 160 t-stat and play with the fans, when you drive it hard or it's hot outside , it will go over 200 in a heartbeat.
with a larger radiator , mine never goes over 198 where's EVIL-TWIN ? he can explain it to you.............lol
I just gotta laugh at weekend warrior mechanics
and
When I foolishly tried that 160 stat with a stock RAD. I ran 220-235.
With a 190 stat and a real RAD. I run 198 max no matter what.
Go figure it out .
and
too cool also can COST you power
you want cold air, not cold motor
etc., etc., etc.
I guess the real point to this argument is the following:
Originally Posted by SickRick
Aside from all the cool scientific explanations/justifications posted here, the fact of the matter is, that the engine runs in the +190 range normally - above the opening temp of the thermostat, whether OEM or the lower temp one.
The only thing a lower temp thermo will do, is open the block to the cooler coolant in the rad SOONER. The engine is SUPPOSED to run at operating temperature - mine gets there in under 5 miles here in SoFla. So regardless, the 'stat is going to be OPEN anyway.
In COOLER climates, the thermostat allows the engine to actually GET TO operating temps sooner, as 30* weather is going to keep your coolant temps down alot better than the 90*+ we get here in SoFla 11 months out of the year.
These engines are designed to run at the 190+ mark. Whether the 'stat opens at 160 or 185, it has NO EFFECT on temps once the engine reaches DESIGNED OPERATING TEMPS - as it's wide open anyway.
Rick
Cheers!
Old Jan 2, 2006 | 10:29 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Jan 2, 2006 | 10:54 AM
502ci's Avatar
502ci
I metioned that I race my car I assume anybody reading this took my choice of the 160 into consideration for this choice. What I did not expect was how well it worked on the street. Heavy traffic never brought the temp. over 200(remember you need to change the fan settings). Overall it runs at 190 and doesn`t flucuate. But at the track it is cooler between rounds. Apparently there is just a few of us that race these factory race cars. I did forget to mention I don`t have cats.
