CAGS brings out the check engine light
Old Aug 3, 2001 | 09:53 PM
Jlborba's Avatar
Jlborba
Default CAGS brings out the check engine light
I purchesd a CAGS unit from Mid-America and installed it today. When I take off and the 1 to 4 shiftlight comes on the check engine light comes on. I can reset the DIC, however the light will come back on and stay on with the next shift light. My DIC error code is P0804 which is a the shift lamp control circuit. Do i need to return the CAGS? :confused: Help
Old Aug 3, 2001 | 10:25 PM
Jlborba's Avatar
Jlborba
Default Re: CAGS brings out the check engine light (Jlborba)
Disconnect the CAGS and the check engine light and code do not show up anymore. Bad CAGS or something else? :confused:
Old Aug 3, 2001 | 10:27 PM
BruceF's Avatar
BruceF
Sounds like a defective CAGS bypass.
Old Aug 3, 2001 | 10:43 PM
Clay's Avatar
Clay
You must disconnect your negative battery cable before installing the CAGS bypass. Not trying to insult you, but some people forget this part and it always causes a code.
[Modified by Clay, 8:50 PM 8/3/2001]
Old Aug 3, 2001 | 10:49 PM
Jlborba's Avatar
Jlborba
Disconnected battery for 10 minutes and still the light came on
Old Aug 3, 2001 | 10:51 PM
jschindler's Avatar
jschindler
This is not typical. I don't have the answer, but I know there is one. I've installed two CAGS with no such problem.
Clay's Avatar
Clay
Definitely a bad bypass then.
Old Aug 3, 2001 | 10:53 PM
Clay's Avatar
Clay
Default Re: CAGS brings out the check engine light (Clay)
I understand you disconnected the battery for 10 min. But, was the battery disconnected at the time the bypass was installed, or after the fact??
Old Aug 3, 2001 | 11:06 PM
Jlborba's Avatar
Jlborba
Before the CAGS was installed and 6 hours after
Old Aug 3, 2001 | 11:07 PM
Jlborba's Avatar
Jlborba
Should I try it all over again and disconnect the battery for a longer time. The battery means a lot right?
Old Aug 3, 2001 | 11:22 PM
mikeyc6's Avatar
mikeyc6
When I installed my CAGS bypass, I didn't bother to disconnect the battery. I did read the instructions but chose to omit that step to see if it would work without having to reset everything in the car and make the PCM learn again.
It worked fine for me without disconnecting the battery. I got no codes or check engine light and the bypass worked fine. I'm not trying to be argumentative, but I certainly didn't have to disconnect the battery. I just figured it was a precaution.
The PCM can't constantly be checking sensors even when the key is off. Can it? That would seem like a horrible waste of power.
Mike
Old Aug 3, 2001 | 11:26 PM
Avanti's Avatar
Avanti
My understanding is that the "GAGs" :lol: bypass has a resistor in it to "fool" the computer into thinking it is still hooked up. If you have followed all instructions to-a-T it would seem that perhaps your unit has a faulty or incorrect ohm-rated resistor. Return it and try again.
Old Aug 4, 2001 | 12:51 AM
LoneStarFRC's Avatar
LoneStarFRC
It very well could be an "open" in the circuit due to broken wire in CAGS bypass or possibly a broken or bent connector pin. If there is an open circuit the computer thinks the connector to the CAGS solenoid is disconnected and generates a code. Easiest thing to do would be to replace CAGS bypass unit. I installed mine without disconnecting the battery (2 years ago) with no problems. :D
Old Aug 4, 2001 | 08:48 AM
AFVETTE's Avatar
AFVETTE
I must have missed the battery dis-connect step. But I haven't had any error codes pop up. Guess I got lucky.
Tom
USAF Retired
[Modified by AFVETTE, 6:51 AM 8/4/2001]
Old Aug 4, 2001 | 11:11 AM
CP's Avatar
CP
Default Re: CAGS brings out the check engine light (AFVETTE)
No problems like that with my installation. Sounds like a bad CAGS eliminator. :cry
Old Aug 4, 2001 | 12:16 PM
CAU-LLC's Avatar
CAU-LLC
Default Re: CAGS brings out the check engine light (CP)
Some of the CAGS Eliminators have a "WEB" inside of the conector of the CAGS Eliminator that you have to take out. This "WEB" inside the conector will not allow the other end to go in far enough.
Before we started making our own we would take a plyers and take this piece out. Now ours are machined out.
Jim Booth / Corvette Accessories Unlimited http://www.CAU-LLC.com
[Modified by CAU-LLC, 11:11 AM 8/4/2001]
Old Aug 4, 2001 | 04:23 PM
JohnGlenn's Avatar
JohnGlenn
I did it this way. It costs about 5 cents: http://www.ls1.com/link_cags.html
To CAGS brings out the check engine light
Old Aug 4, 2001 | 08:14 PM
Jlborba's Avatar
Jlborba
Default Re: CAGS brings out the check engine light (JohnGlenn)
Great idea, Thanks!! :D
Old Aug 4, 2001 | 09:55 PM
LoneStarFRC
:cool: idea. After all, a GAGS eliminator is only a resistor that provides just enough voltage drop to the actuating signal so that the computer thinks it really actuated the solenoid. I prefer to have have the GM Weather-Pak connectors and not have to worry about moisture/corrosion etc.
[Modified by Tx99FRC, 7:55 PM 8/4/2001]
Old Aug 4, 2001 | 11:00 PM
av8or3's Avatar
av8or3
I used the 220k ohm resistor bypass myself with no problem.You can buy a
card with (5) of these resistors @ Radio Shack for .79 cents.Fix yours up & pass the others out to friends.Good luck!
