Stripped lug nuts
Old Aug 3, 2001 | 10:42 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Stripped lug nuts
My wheels have been off/on the car about a dozen times, I always used a torque wrench or had the shop use one. Last week, the shop used anti-sieze (!) on the lugs when they installed the wheels, then torqued them to the manual spec of 100 lb/ft. When I noticed the goop, I raised hell and so today they removed the wheels, wiped off the goop and sprayed with brake cleaner, then reinstalled. Bad news- the tech said that the nuts felt "mushy", and when we removed one, we could see a tiny spiral of loose metal inside. So we junked all the nuts, recleaned the studs, and reinstalled the wheels with new nuts. This time the nuts felt normal under the torque wrench, and the stud threads, to my uneducated eye, looked normal. Big questions:
1. Does the anti-sieze reduce the friction so much that the lug nuts stripped at 100 lb/ft, or did they just wear out from a dozen times of on-off?
2. What are the chances that the studs are damaged, and how can I really tell?
Thanks for the help!
Old Aug 3, 2001 | 11:03 PM
AZ C-5's Avatar
AZ C-5
Default Re: Stripped lug nuts (Gearhead Jim)
I have never had the threads pull out of the nuts...Have had the bolts stretched and ruined the bolt threads which locked the nut to the bolt resulting in breaking the bolt. This is done by shops using high torque air wrenches..not torque wrenches.... I have used anti-seize before but not on the Vette, with no problem.
Old Aug 3, 2001 | 11:53 PM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Stripped lug nuts (AZ C-5)
I agree. Somebody really torqued those nuts.
Bill
Old Aug 4, 2001 | 12:19 AM
MDT's Avatar
MDT
Jim,
The manual says to torque 'em dry. I can't help but think that a light coat of engine oil would NOT affect the torque that much, but I guess it comes down to an individual judgement call.
Good luck.
Mark
[Modified by MDT, 10:20 PM 8/3/2001]
Old Aug 4, 2001 | 12:45 AM
Speed-Racer's Avatar
Speed-Racer
Default Re: Stripped lug nuts (MDT)
Yes, I torque mine dry by feel. I instictively know about how much to tighten
George
To Stripped lug nuts
