Was wondering if anyone out there knows what a H P0307, P P0307, H P0300, DTC codes are?
I just bought a C5, and it is running rough at idle and smells really rich.
I'm assuming that it has some bad O2 sensor, but do not know for sure. Does anyone have any suggestions?
Yep it's a Cycl #7 missfire, and random missfire code. I'd check the easy stuff, inspect the plug wire & the plug first.
Smells rich most likely due to the miss fire. Does it missfire under load / acceleration? Or only at idle.
-=Rick
It miss fires at idle, but when I lean on it a little it seems to go away??
I thought at first it was in a limp mode, but I reset all dtcs and it still runs the same.
Hmm.. I'd still check the ignition components but you could have an injector that is leaking, in other words your demand for fuel is minimal at idle if more fuel is entering the cyclender that could cause a miss and the fuel smell....
Off idle / accel your demand for fuel increases so if an injector was leaking it might not show it's effects...
Just some ideas..
How does it start after sitting a long time, does it fire right up? When you first start it are you getting a nice puff of fuel vapor out the pipes?
Just some ideas..
-=Rick
It fires right up, and yes it puffs a little. I'm trying not to run it a lot more, until I get it fixed. I dont want to blow the mufflers off the car.
vac leak around #7 intake? spray alittle carb cleaner there see if miss goes away.It's not hard to swap injectors and see if misfire follows. What color smoke? if blue,pull the plug and look for oil
must be excessive fuel to be black,fuel leaking into cylinder,injectors that spray to much is extremely rare(stock,factory anyway).I've replaced O2 sensors that told PCM its lean when actually its too rich, but it should affect other cylinders. You can unplug the sensors(or swap side to side) and see if you condition changes(only will work after about 2-3 minutes of run time, sensors need to warm up and go to closed loop)Is the car stock?You can disconnect #7 injector and find out if rich exhaust goes away
