k&n air intake
Old Jan 5, 2006 | 03:12 PM
folsomlarry's Avatar
folsomlarry
Default k&n air intake
Have a chance go pick up a almost new k&n system for my 99 FRC. I have read a lot of the discussions on the various types of intakes and was going to go with the Z06 box until the k&n came for sale locally.
This seems to be the only system that no one seems to talk about. Is it that bad?
Thanks for any thoughts on the subject.
Old Jan 5, 2006 | 04:17 PM
FastCashDave's Avatar
FastCashDave
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Works Great For Me
Been using it for two years on my Nitrous Motor
Old Jan 5, 2006 | 04:40 PM
folsomlarry
Thanks for the reply. I wanted to stay with something that is legal in California, which seems to narrow the field.
Old Jan 5, 2006 | 05:10 PM
EHS's Avatar
EHS
As good as any of the other intakes, give or take 1/2 a horsepower.
Old Jan 5, 2006 | 05:35 PM
jrose7004's Avatar
jrose7004
I like my K&N set up!
Old Jan 5, 2006 | 08:16 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Old Jan 5, 2006 | 09:43 PM
frc's Avatar
frc
Originally Posted by navy99vert
Old Jan 5, 2006 | 09:50 PM
MrLeadFoot's Avatar
MrLeadFoot
If it's the one that splits into two, I would think that would be good, 'cause it brings the filters down closer to the fog light area, and if you open up the fog light bezels, you have cool intake air going right to the filters. I wanted to go that way, but the Halltech Stinger deal was too good to pass up a while back, so I went with that instead.
If it's the single K&N, it's probably just as good as the Halltech Stinger.
BTW, I'm in EDH. Nice to see a neighbor on the forum.
Old Jan 6, 2006 | 10:35 AM
folsomlarry
It's actually the single filter model. Just starting to make some modifications to the car. Was going to do some track days with it, but now I think I will just put a few "bolt on mods" and build some kind of a track day car.
Now I need to get into a Corvette club so I can start attending some events.
Thanks for all of the replies.
Old Jan 6, 2006 | 10:57 AM
MrLeadFoot's Avatar
MrLeadFoot
Every once in awhile I see a Corvette Club showing their cars up at the old Sam's parking lot, at the Cameron Park exit off of 50. If you're up that way on weekends, you might want to make it a point to get gas and food at that exit, on the chance you might run into them.
Too bad I can't remember the name, because several of them were nice enough to start up their cars, so I hear all the different exhausts they they had. I actually got to hear all the varieties, with and without x-pipes, and the works. I think some are actually on this forum, so I'm sure posting an enquiry will draw some replies.
Old Jan 6, 2006 | 03:04 PM
BMG50's Avatar
BMG50
Originally Posted by frc
ON my 97 and 99 FRC
Old Jan 6, 2006 | 03:31 PM
dyal980's Avatar
dyal980
Old Jan 6, 2006 | 03:43 PM
Gordy M's Avatar
Gordy M
In a drag race, you should see some benefit over a stock system. Any increase would be due to cooler incoming air and at idle to 50 mph is the place you will see the most gain. When running a road course, you will experience very little, if any, benefit as the IAT will usually not be that different from one enclosed system to another. Also, in a stock system, stay away from larger smooth couplers. They actually slow down the incoming air passing through the MAF. The computer then thinks you are going slower than you actually are and can either decrease the fuel available or take out timing.
Plan you mods carefully and remember most of the marketing claims contain large amounts of air. Good mods and tuning is where the gains are found.
Old Jan 8, 2006 | 02:00 AM
BrianWe's Avatar
BrianWe
I went with the Z06 airbox cover, K&N filter, WCC cold air screens, and performance hood seal . I have a 2004 A4 with 2.73 gears and there is a noticable increase in power. Very easy to spin the tires at a light now. It is louder than before so you can hear the power. My $0.02. I am happy with it.
Old Jan 8, 2006 | 02:07 AM
DuffyN's Avatar
DuffyN
Very cool. I have an 04 with the auto and 2.73 Do you shut off the traction control to spin the tires or just punch it????
Thanks!
You air setup sounds very nice
Old Jan 8, 2006 | 02:12 PM
MrLeadFoot's Avatar
MrLeadFoot
Wait a minute... the MAF is right after the filter element, BEFORE the coupler at the engine. This means the MAF is measuring air coming in at the filter... air that hasn't even hit the coupler/air bridge yet. So I'm not so sure what you're saying is true here. Unless I'm misinterpreting what you're trying to say here, which has happened once or twice.
Old Jan 8, 2006 | 05:27 PM
Internets_Ninja's Avatar
Internets_Ninja
i love my K&N single filter kit
To k&n air intake
