Headlight Relay Mod
2. Locate plug for headlights/motor on passenger side and disconnect it.
3. Run #12 AWG wire from fusebox to relay location and connect to pin 87.
4. Tap into high-beam (green) wire and connect to pin 86.
5. Tap into low-beam wire (brown) and connect to pin 30.
6. Tap into ground wire (black) and connect to pin 85.
7. Connect #12 AWG wire from step 3 to +12V. I ran mine to the large nut on the fusebox with the two red cables. I will probably add an inline fuse next weekend.
8. Test the system. If everything is OK, screw relay to fenderwell.
I used the insulated crimp-on female lugs on the relay. Also available at Radio Shack. See this diagram for example of wiring:
http://home.comcast.net/~silver2001c...4/site1037.jpg
Ignore the instructions on the drawing, as they are for another application, but it wires about the same. Your high-beam wire that is connected to pin 86 will trigger the relay, providing 12V to the low-beams. Mine worked great in testing, but as I said earlier, I haven't actually used it at night.
I will try to get some pics tomorrow.
1) Both yours and Eckler's instructions mention tapping into either the left or right harness that goes to the left or right lights. Does that mean that you do NOT have to tap into BOTH sides, and that the lights for both sides are on the same circuit? I always thought the circuits were separate.
2) I noticed that the light green and the tan wires in the harness between the fuse block and the connector near the lights have a black stripe. Are those the wires I should tap into?
3) I also noticed that those wires are very small. They look like they're only 16 or 18 gauge. While I will run a 12 guage power wire to the relay, as you instructed, is it ok for me to use only 16 or 18 gauge to the green and tan and black wires?
4) I'm also going to put an in-line fuse between the relay and the power tap at the fusebox. Since the relay is 30 amps, should I use a 30 amp fuse? 30 amps seems kind of high considering that the headlight wires are so small. I would think there's a lot less current going down those wires and a 30 amp fuse seems like it might not provide the appropriate protection.
Sorry for all the questions.
2) Use the side of the harness closest to the headlight. You will see three wires under one black tube. These are for the lights. The two wires are for the headlight motor. See pics.
http://members.***.net/kcrocker/relay1.jpg
http://members.***.net/kcrocker/relay2.jpg
3) I used #16. That is about the same size as the factory wiring. I only used a #12 for the power feed since that is what I had on hand.
4) The relay contacts will handle 30 amps. The total draw for both lights will be 130 watts, or about 10 amps. I would use a 15 just to be sure.
The problem with the corvette system is nothing goes to absolute 0v and if it does the computer wants it that way.
So a current limiting diode will prevent feedback thru the system.
I could build a harness so you wouldn't have to splice anything.
I have been thinking about putting it on our site and make it available for purchase.
The problem with the corvette system is nothing goes to absolute 0v.
For example:
1 Relay $6.29
1 In-line Fuse box $2.59
1 Fuse $.50
6 Blade Connectors $1.13
3 splice connectors $1.20
10ft. of 14 gauge wire $1.50
That totals $13.21. The Eckler's kit is $47.99! That's nearly 391% of what it would cost in RETAIL parts!
Correct me if I'm wrong, but buying the individual parts that make up almost any kit usually costs MORE, not LESS than a kit.
And, that's not even considering how much those parts are wholesale. Let's say those parts really cost $7. Throw in the convenience factor and a kit should really cost no more than $21 retail, don't you think? OK, now let's add your stuff. Now the kit should be, what, $25 - $27? And that's with your harness and diode. C5 owners that don't want to go HID or Euro would be all over that.
If you want, you could even add some PIAA 9005s for the highs and modified PIAA 9005s for the lows (or the Japan 9006 version which is almost as bright as the US 9005s, but fit in the 9006 slot without modification), and you have an all-in-one plug 'n' play kit. Sell that for $110 -$120 and you have a winner for C5 (and more) owners who prefer not to modify their lighting with HIDs or Euros.
Wait, I think I'm getting ahead of myself here.
I'll put all the stuff in within the next few days and report back as to whether these combined mods are worth it. From what I've seen on the reports of the individual mods alone, I'm expecting quite an improvement.I better include a Non-disclosure Agreement with my report, just in case... and maybe we'll become venture partners.
If you are going to put better bulbs in do it right consider the HIR1 Bulbs
A harness adapter could be made to make it fit in the plug for the low beam slot.
Also you could do a few other things to make swap easy.
I am Also working on a non relay system for what you are doing.
I have to put some more math down and make sure in event of short the system will act as designed from gm. I have a test harness built and will try and test it next week.
Stock Corvette C5 low beam bulb: 9006. Produces 1000 lumens.
Stock Corvette C5 high beam bulb: 9005. Produces 1700 lumens.
New bulb: HIR1 9011. Produces 2500 lumens.
Not saying that you are wrong, just sharing.
(Ok, so now you have a deluxe kit you can sell for $135!
)Just because they sell it that way doesn't mean it is right.
I might be wrong but the corvette lighting circuit is a 4 fuse system 2 per side .Ill look up prints tomorrow,
Weather pack connectors $5 each with pins. 4 needed
Seals another 2.00
Then the time involved to produce it and test.
Diode maybe $0.20
Then you have to hope you do not get sued
And what do you mean:
Incidentally, ever since I owned a C4, I've always wished that the lows would stay on when the highs were on, thus my wanting to do the relay mod.
Seals another 2.00
Diode maybe $0.20
Just like many others on this forum, I figured I'd try what I'm trying first. If it serves MY purpose, great. If it doesn't, and I determine the extra expense is worth it, maybe I'll end up with your HIDs down the road (no pun intended), too. /QUOTE]
I have a plan but I want to make sure it is right before it is released to public. I am not willing to risk everything on something that was not thought thru completely.
The common is the headlight module and the relay.
Fuse #8 Low beam right
Fuse #9 High bean right
Fuse #10 Low beam left
Fuse #12 High beam left
So in essence you actually have 4 individual circuits.
Sp no matter what you do with a single relay system. You are still straining the electrical circuit and defeating the safety feature of the electrical circuit.
I mounted the relay in the battery compartment next to my Home Depot catch-can, instead of on the fender well. I also grounded to an existing frame ground for good measure. I installed an in-line 20 amp fuse, because I thought that since the lights were on 10 amps (did not know about 4 fuses), I was doubling the draw. Someone let me know if I need a lower amp fuse. ! have 15s around, so I can substiitute one of those instead.
I used 14 gauge for power an ground, and 18 gauge on the tap into the harness. I was going to use 14 all around, but found the factory wires were smaller. In the end, I noticed that the factory wires were really 20 gauge. That's so weird, because although the harness is 20 gauge, the wires to the plugs at the bulbs are 12 gauge. I guess GM figured that there would be more stress on the bulb connector wires, since they're moving around when the lights go up and down, and are moved when bulbs are changed.
It's still light out here on the West Coast, so I cannot report the results, yet. However, even with the one stock high beam bulb in place, even in full daylight the lights look whiter. No hint of blue shows at all, not even when the lights are up, but not on. So far, so good.
Now, if only I could find duplicate male and female connectors for my hood light, I can wire in a manual switch, instead of leaving the harness disconnected all the time, because I hate connecting and disconnecting the harness. I ususally just leave it disconnected all the time, since I'm undere the hoos so often. But, that's another story.
BTW - I am an electrical engineer.
Think about it You are powering Both sides with one sides circuit.
The only reason the other side is powered is because you are pushing electricity backwards thru the circuit to the other side.
