Seafoam: can it do any harm ??
#41
Originally Posted by Robbo
I have a 98 coupe with 125,000 on it and don't know the history (only owned it since 118,000 and August). I think I will try to cover all the bases. Anyone see anything wrong with this plan?
Pour half of one can in the oil ~250 miles before oil change is due and pour 1 can in the gas .
The day before the oil change I think I'll try the 4oz in each cylinder and turn over w/o plugs then let sit overnight. Next day will run the car until it stops smoking and then change oil and put new plugs/wires (don't know when the plugs/wires were changed last).
Any other related suggestions to go along with this that you would do with the mileage/unknown history?
Rob
Rob
Have you done the Sea Foam decarb yet. I have a very similer situation with a 99 coupe at 120K miles that has consumed 1qrt per 700 - 1000 miles from day one. Motor has never been decarbed yet but since I just installed a AMW catch can and will do the LS1 to LS6 pcv mod next week when I change over to a LS6 intake I thought now would be a good time. Reading through all the post outlining the varrious methodes I thought yours sounded resonable. How it all turn out?
#42
Originally Posted by dudleyd
Rob,
Unfortunately I haven't done it yet. It's just the plan I came up with. I have quite a few miles to go before the next oil change (about 2k) but when I do I'm going to follow that plan. I'll let you know how it turns out... or if you get to do it before me... let me know how it turns out for you.
Rob
#43
Sorry to bump such an old thread.
I am wanting to do this.
I never ran a fuel injector cleaner or upper head lubricant but have been told to do so. I bought lucas fuel cleaner and upper engine lubricant and poured the small bottle in the tank. Too early to see any results.
However I've done seafoam in the past and it helped with some older cars. Just scared to do this to my vette...
I am reading some of you guys put half of the seafoam in the oil??? before an oil change. Never heard of that before? Drive the car around like that? That sounds scary!
#44
Banned Scam/Spammer
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,916 Likes
Also curious about whether Seafoam in the gas tank could cause any issues. I have a fuel gauge that doesn't read properly sometimes and is likely due to deposits on the fuel level sensor(s). Tried Techron already, but wondering if Seafoam would do a better job, and safely.
#46
I seafoamed my gas tank twice so far to unstuck my gas gauge. Worked with no issue so far. Now my level gauge goes up or down instead of staying at a quarter tank after a fill up.
ArmchairArchitect (06-23-2017)
