LG Pro install
Old Jan 8, 2006 | 11:21 PM
minytrker's Avatar
minytrker
Default LG Pro install
I got to work on it about 4 hours off and on, that includes running back to auto parts since I have an empty can of anti-seiz. I have the driver side done and all back together. I pulled the passenger side apart and removed the starter and its ready for the header. I just ran out of time. So far it hasnt been to bad, cant wait to get it finished.
Old Jan 8, 2006 | 11:30 PM
Wisdom's Avatar
Wisdom
On your back or on a lift?
Old Jan 8, 2006 | 11:40 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
LG Install isn't bad on your back either.. Pretty easy headers to install..
You WILL Notice an improvement in sounds, and TQ...
steve
Old Jan 9, 2006 | 02:24 AM
minytrker's Avatar
minytrker
On my back. I bought some 6 ton jack stands that hold the car high enough easily. I could have done it on a lift next week but figured I would try it the hard way. Its reall not a bad install at all, well atleast the side I have done already wasn't bad.
Old Jan 9, 2006 | 05:34 AM
terlox's Avatar
terlox
Sounds like you're moving right along. I don't know if LG recommends you remove the passenger side valve cover or not, my Dynatech instructions said it should be removed. I ended up being able to slide the header through the passenger side without removing the valve cover. Good luck, you'll enjoy the gains.
Old Jan 9, 2006 | 10:27 AM
mini's Avatar
mini
I took off my pass. valve cover off to get my LG's in. It fell right in when I did that.
Old Jan 9, 2006 | 12:11 PM
bennettrp's Avatar
bennettrp
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
Put the street series on a week ago. Pulled off the valve cover and it dropped right in. Did not have to move the starter. Just took a little "nudge".
And I haven't done one of these in 25 years.................
Old Jan 9, 2006 | 05:23 PM
Nithros's Avatar
Nithros
St. Jude Partner since 89
St. Jude Donor '09
I put the passenger side in from the top by just taking the coil packs and oil tube off that side. Instead of a nudge, I'd try a twist and they go right in.
Old Jan 9, 2006 | 08:01 PM
minytrker's Avatar
minytrker
I didnt work on it today but I will finish it tomorrow. It shouldnt take long, all I have to do is drop in the passenger header and put it back together. The driver side is all put back together.
Old Jan 9, 2006 | 08:18 PM
LG Motorsports's Avatar
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Hi guys,
There is alot of good info here. You guys are tougher than I am, putting your headers on without a lift.
Lou G
Old Jan 9, 2006 | 09:23 PM
bennettrp's Avatar
bennettrp
Originally Posted by LG Motorsports
Hi guys,
Lou G
Lou,
You da man!
Headers sound sweet. And the power increase (without tune yet) is impressive.
You aren't gonna make any points with the wife, but, then again, that's my problem.
D
Old Jan 10, 2006 | 03:55 PM
minytrker's Avatar
minytrker
Header install is complete!!! It took about 6 hours taking my time with hand tools. I did it on jack stands, and I am not sure how much easier a lift would have made it, since it wasn't bad. When I do my friends car I may do his on the lift just to see which is easier. The headers sound great, my car sounds completly differnt now. I already had borla mufflers, so now with headers and no cats its pretty loud when you get on it. The only thing 2 things I didn't like were the cheap header gaskets that were included and they didn't come with no plugs for the rear o2 bungs. I had to install my front o2's in the holes to plug them since I can't find plugs that size anywhere local.
LG Motorsports customer service is top notch, and very friendly when you call. I look forward to doing business with them again when I buy my cam.
Old Jan 10, 2006 | 07:58 PM
turboc5's Avatar
turboc5
LG
Old Jan 10, 2006 | 11:43 PM
Shane_S's Avatar
Shane_S
Originally Posted by turboc5
LG
Shane
Old Jan 11, 2006 | 06:12 AM
wrustywrench's Avatar
wrustywrench
just asking, why not run all 4 sensors....front and rear???
use the OEM gaskets, they work fine and last long time
Old Jan 11, 2006 | 03:34 PM
dudleyd's Avatar
dudleyd
What did you use for the front O2's, doesn't the PCM require them for correct air fuel mixture?
Old Jan 11, 2006 | 05:08 PM
minytrker's Avatar
minytrker
You install the rear o2's in the front and plug in an adapter that comes with the headers to plug into the wiring for the stock front o2.
Old Jan 11, 2006 | 05:10 PM
TheCartel's Avatar
TheCartel
Negative. Without cats you only use the rear o2's in place of the front sensors. Without a tune you'll use the supplied sims. I did'nt like not getting plugs for the rear bungs either, but I picked some up on ebay..
Jason
Old Jan 11, 2006 | 10:48 PM
minytrker's Avatar
minytrker
Jason
We said the same thing. My headers didnt come with sims just the adapter to plug the rear o2 into the front plug.
To LG Pro install
