LS1 heads, CNC or Prof. ported/polished
Old Aug 4, 2001 | 09:36 PM
HP JNKEY's Avatar
HP JNKEY
Default LS1 heads, CNC or Prof. ported/polished
Do cnc heads make more hp. than heads that have been professinally ported and polished? Seems like alot of coin for cnc heads and you have to give up your original parts as a core. I would think that for about 1000.00 to 1500.00 you could have a pro. do alot to your original heads. What do you guy's think? Also : Would the new 2002 Zo6 cam c/w ported/cnc LS1 heads be a good combo or should one go with a package from MTI or Agostino?
Old Aug 4, 2001 | 09:49 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: LS1 heads, CNC or Prof. ported/polished (Finelee)
I think the tuners have been making more power than CNC heads. :smash:
Old Aug 4, 2001 | 11:06 PM
A C's Avatar
A C
Cruise-In II Veteran
CNC is just a method of machining. You can get more power out of hand ported heads, but they can't be mass produced with the same results. I am actually very surprised that the aftermarket head companies (Brodix, Dart, AFR, Canfield...etc) haven't latched on to the LS1 yet. It's easy to see from this forum that there would be a demand.
AC
[Modified by A C, 9:10 PM 8/4/2001]
Old Aug 5, 2001 | 01:48 AM
Speed-Racer's Avatar
Speed-Racer
Default Re: LS1 heads, CNC or Prof. ported/polished (A C)
Get your heads CNC's then hand polished. CNC' can leave behind swirl marks from the cutter.
George
To LS1 heads, CNC or Prof. ported/polished
